Question about ASUS Computers & Internet
Laptop Screen is broken - ASUS Computers & Internet
  • 846 Answers
Try to find the part in an auction using the exact model number of your laptop. Laptop screens start at $100. To make it worth it though you may need to self-install. There are repair guides online, it's not that hard on Dell at HP laptops. Just remove the front bezel, release LCD plug and backlight plug, remove the defective screen and replace it with the new one. I work for a laptop repair company (Laptop Repair NYC) and we do this replacement frequently in an hour or so.
Posted on May 12, 2009
    Sergeant:
  • 268 Answers
Laptop screens are usually very pricey to fix. Chances ar eyou will need a new one , and the price of a new one + labor for someone to install it usually isn't worth it. For the same price you can purchase a brand new one!
Posted on Sep 30, 2008
Asus Laptop Screen is broken
Search ebay for the screen.
The link below will tell you how. How to replace broken laptop screen
Mar 26, 2014 | Computers & Internet
Broken laptop screen
There is nothing more frustrating than a broken laptop screen. Whether you have dropped your laptop or stepped on it,once the screen is cracked it has to be replaced. Having the screen repaired may cost you almost as much as a new laptop. Purchasing a new screen from the manufacturer can also be expensive. Taking the time to look online at computer message boards or resellers can help you to find a reasonably priced screen. By following a few easy steps, you can replace your cracked screen and have a functioning laptop in an afternoon.
Determine what model laptop screen will fit your laptop. Ordering a screen directly from the manufacturer can be almost as expensive as buying a new laptop. Look at online computer message boards, auction sites and retailers to find less expensive options. Disconnect any power source, including the battery pack, from your laptop before you begin. Locate and remove the four to six screws that hold the bezel, or plastic frame cover, in place. The screws sometimes have small plastic or rubber covers over them. Pull the plastic bezel away from the screen cautiously, working around the edge. Some bezels snap in and out of place. A small flat-head screwdriver may be helpful in prying the edge of the bezel away from the screen. Pull the screen forward gently. You will find two main wires behind it. The ribbon-like wire, or video cable, is usually taped in place. Remove the tape and disconnect the video cable from your broken screen. Remove the broken screen from its metal frame. Connect the new screen to the video cable and pop it into the metal frame. Replace the tape, plastic frame and screws. Power up your computer and test your new screen. Hope this helps.
b>
Dec 10, 2012 | Computers & Internet
Samsung laptop broken screen
go to samsung authorize care centre.they will fix ur screen
Nov 29, 2012 | Computers & Internet
I dropped my laptop on the floor, it fell on a corner, the screen is scrambled on the right side for 1 inch and the top right corner is black like a broken window what shouls I do? Thank you
You can either replace the screen or you can work on your laptop with a broken screen. Replacing the laptop screen is quite costly depending on your laptop model and availability of your parts.
Jul 27, 2010 | Computers & Internet
How to use a laptop with a broken screen
u can use it with another laptop.all u will do is to turn the broken one to pc and use with another one
Dec 29, 2009 | HP Pavilion dv9000z Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
Broken Inspiron 1525 Lid
hello
To fix your laptop follow the steps given below.
  • First of all as your hinges are broken you have to buy a pair of hinges for your laptop model.
  • This hinge includes the whole assembly made up of metal with a part which attaches your screen to the laptop.
  • Now you have to open up your laptop from the backside and disassemble the upper side.
  • This will make you see the part which detaches tour screen from the laptop.Just remove the screws and your screen will be completely detached.
  • now you can replace the damaged hinges with the new one.
  • you have to remove four screws for one hinge.Two screws supporting the screen and two attaches the screen with the laptop.
  • so remove these screws and replace the hinges and pack the laptop again.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
Aug 21, 2009 | Dell Inspiron 1525 Notebook
Nec laptop screen not displayin
What have you tried so far?
Connect your laptop to an external monitor to see if it is the adapter or the screen that is broken. Toggle on to the external monitor. If the external monitor works, you'll know it is the laptop screen(or a component of it) that needs repair
Check your laptop latch to see if it is broken.
Dec 15, 2008 | NEC MultiSync FE991SB 19" CRT Monitor
LCD PROBLEM
if you can get hold of a second Dell Lappy (same model) which is broken (not broken screen) you can swap the broken screen for the good one. It means opening the laptop, but due to the smashed screen the warranty is invalid anyway. There is usually 1 or 2 cables coming from the screen 1 for signal and 1 for power. you can explore the broken lappy to see how the screen connects,
Oct 08, 2007 | Dell Latitude C640 Notebook
Computers & Internet Logo
125 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
