There is a line of light across the center of the television screen, is the picture tube burned out and is it expensive to replace if it can be replaced?
I ahve the same problem- same exact day as you. There is a horizontal line in the center of the screen. It is very bright. I changed the fuse, did not solve the problem. I can hear the program on the tv- just can't see it. Thanks for any help, JudyI ahve the same problem- same exact day as you. There is a horizontal line in the center of the screen. It is very bright. I changed the fuse, did not solve the problem. I can hear the program on the tv- just can't see it. Thanks for any help, Judy
Sound works great, just have a very bright horizontal line right in the center of the T.V. ? any ideas before I spend an arm and a leg for a new one??Sound works great, just have a very bright horizontal line right in the center of the T.V. ? any ideas before I spend an arm and a leg for a new one??
I have a 50'' Panasonic plasma and a thin black line has only started to apear but will not go away. Tried adjusting everything but no luck. Has anyone got any idea what this is? Have had the tv for about 18 months.I have a 50'' Panasonic plasma and a thin black line has only started to apear but will not go away. Tried adjusting everything but no luck. Has anyone got any idea what this is? Have had the tv for about 18 months.
You can't post conmments that contain an email address.
There is a failure in the vertical deflection circuit. Typically there is a vertical output i.c. that provides the deflection vertically. The i.c. itself is a fairly common component to fail. There are some lower power circuits that feed this output device that also could be the problem. When the electron beam in the tube is not deflected vertically it "writes" only horizontally across the center of the screen thus resulting in a single trace. Be careful not to leave this at high brightness for any extended time as it can "burn in" that area of the screen. Unless you are a "techi" this is a job for a qualified technician. Troubleshooting would be in the vertical deflection section of the set. Most of the parts are not expensive in themselves, except for the deflection yoke which sits around the neck of the tube. The cost to repair would typically be the shop labor.
No, your picture tube is fine. This is a problem in the vertical circuit that deflects the beam up and down. This repair is fairly typical across most television brands and should not cost too much to fix. I don't want to quote another shops pricing but from us this would run about $150.00 to fix.
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
1. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor usually gets it working perfectly again.
or
2. The vertical drive IC has failed.
If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
so check the supply of vertical IC if its ok ,re solder the ic.
How do I actually do this?
