Fax to document tray won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time.
Hence, require cleaning or replacement if worn out. In case you find
them dirty use
a soft, dry, lint free cloth to clean the rollers. Dont use chemicals
as they may damage the rubber and plastic. However, if needed, you can
use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
