My monitor has a message floating up and down saying not optimum mode recommended mode 1280x1024 60Hz what do i do
    Scholar:
  • 89 Answers
You will have to change the resolution of your screen as well as the refresh rate. Go to the Display settings of your computer and set the resolution to 1280x1024 and refresh rate to 60Hz.
Assuming you are using windows vista:
Right click on your desktop and select Properties > select Display settings > change the resolution to 1280X1024. Go to Advance button > Monitor tab and set the rate to 60Hz. Click Apply then OK.
Good luck and have a nice day!
Posted on Sep 30, 2008
  • 38 Answers
Dear dalton,
1.right click on desktop.select properties and click it.
2.then select settings tab on top.
3.there u can see the screen resolution slider bar. there u can select the optimum mode for ur monitor.
thanks,
My computer is on but all I see on the monitor is a floating box with the message "Not Optimum Mode Recommended Mode: 1280X1024 60Hz.
Try connect a different monitor on your computer and change the resolution to 1280x1024. After that, replug the new monitor and it should work.
Feb 28, 2011 | Samsung Computers & Internet
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Screen goes black with a floating sign the says Not Optimum Mode Recommended Mode: 1280x1024 60Hz Took in for repair and work ok there
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
Jan 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
My computer screen has a blue box floating round the black screen, the buttons and mouse dont do anything. There is a message saying 'not optimum mode, recomended mode 1280 x1024 60hz. There is also a...
Basically its telling you to change to the correct resolution. You may have it set too high. If you go into "Safe Mode" you should be able to bring it down. Or if worse comes to worse, uninstall and reinstall your video card. Just make sure to have the drivers available.
Oct 16, 2009 | Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Floating window
HOW MUCH MEMORY DOES THIS COMPUTER HAVE
THIS COULD BE THE PROBLEM DO YOU EVER GET VIRTUAL MEMORY ERRORS
Jan 14, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
