Question about Creative Labs Zen Micro MP3 Player
My zen player prompts rebuilding after turning it on
After turning on the device prompts me rebuilding.....
  • Anonymous Mar 13, 2009
    one day i plugged my zen into the computer and instead of saying Docked or whatever, it said rebuilding. ever since it won't stop! it won't go off (unless i reset it) and it won't come on the computer so i can back up my pics, music, videos, ect.
Mine did the same thing, but i kept trying to turn it on and eventually it just started working
Posted on Dec 02, 2008
Device is hanged in rebuilding
Turn it off completely. Press the reset button using a paper-clip. Then afterwards, flash again the firmware.
Sep 29, 2010 | Creative Labs Zen Digital Media Player
Hi i cant see all my files on device( creative zen microphoto) and it does "rebuilding library" every time i turn it on(if it hasnt been on for a few hrs)?
The software will most likely need to be updated. You can download the software update from the manufacture's website, Or there may be an option on the player itself.
You can hook up to pc, then go to my computer, and then find your Zen and access files here as well.
Nov 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative media player stock to rebuilding
First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 29, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Zen V-Plus freeze at rebuilding directories
YOUR MUSIC FILE IS CORRUPTED.When you hook it up to pc .open the files on the zen and format the music file.If you still have a problem.Format the drive and download new drivers here>http://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Dec 10, 2008 | Creative Labs Zen Neeon MP3 Player
Rebuilding
my zen player freezes up alot don't know why but the only solution i have to any problem is that right next to the slot for my pc plug in there is a little tiny hole. have to find something tiny enough to fit in an gently push in this resets the device
Jul 23, 2008 | Creative Labs Zen Digital Media Player
Zen V plus can't detect by the computer & all the data base losts
Suggestion: uninstall the failed portable device in Device Manager.
Note: You should already have the application for your portable device installed on your computer before continuing.
1. Go to Device Manager and make sure that your portable device is not reporting any problem. If it is, uninstall it.
2. Reconnect your portable device. The computer should detect it now.
Jul 07, 2008 | Creative Labs ZEN V Plus MP3 Player
Rebuilding problem
http://serviceman.site88.net/index_files/MP3Players.htm
Jun 27, 2008 | Creative Labs Zen Touch MP3 Player
My computer won't recognize my creative zen 60 gb mp3 player
you have to format it only
this can through connect device
right click overtheir
and format it
Nov 15, 2007 | Audio Players & Recorders
Creative Labs Zen Micro MP3 Player Logo
91 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
