Question about Frigidaire GLET1031 Top Load Stacked Washer / Dryer
Fridgidaire GLET1041AS1 I have a Fridgidaire model GLET1040AS1 Serial XE21103924 stacked washer dryer whose dryer doesn't heat although the drum turns. I want to check the heating element but don't know how to get to it. Any suggestions? Jay Smith
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Posted on Aug 18, 2010
Can stacked washer dryer be separated?
no that's a one peace stacked washer,dryer
Nov 27, 2017 | Kenmore Dryers
Fridgidaire GLET1041AS1 need assembly/dissasembly schematic so i can take it apart
Good Morning lzook, thank you for your post!
I understand you are seeking a Parts Manual and Wiring Diagram for your Frigidaire washer, GLET1041AS1. I have located information about your washer on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Dec 12, 2013 | Frigidaire GLTF1670A Front Load Washer
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Dec 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
No heat in dryer. This is a stacked dryer/washer combo. The dryer is electric. The drum turns and timer works but there is no heat in the dryer or exiting the vent. The washing maching beneath the dryer...
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Jan 23, 2010 | Dryers
Need 90" Drain Hose for GLET1041AS1 Stacked Washer/Dryer. Part Number on Hose is: 1314612 OEM 3
The part number of your original drain hose is 134049200. There is an 8 ft corrugated drain hose with a part number SSD8 and has a universal end which you can cut to fit, and is approximately 96 inches long. hope this helps.
Oct 11, 2009 | Frigidaire GLET1031 Top Load Stacked...
Fridgidaire dryer
Try You should call service.:
A&E Factory Service
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Jul 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLET1031 Top Load Stacked Washer / Dryer Logo
527 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
