Question about GE Washing Machines
Code ub/u6 appears during spin cycle - GE Washing Machines
  • 130 Answers
SOURCE: LE code -during cycle the drum doesn't spin but just clicks
http://www.howtomendit.com/answers.php?id=28214
click the link directly
Posted on May 07, 2009
  • 120 Answers
SOURCE: Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
Posted on Jun 02, 2009
  • 103 Answers
SOURCE: Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Posted on Oct 09, 2009
  • 143 Answers
SOURCE: error code OF 2
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Posted on Mar 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Spacemaker. Why doesn't it spin?
usually the water empty switch has got stuck in the water present stage that means that the small pipe that feeds the switch is blocked, look for a small pipe about 5mm in diameter and remove it and blow gently inti it you will hear a click and then another as you release it if so then go to the place you took it off and clean the inside of the metal tube and put the tube back on and that should be that I hope that helps a little eric
Dec 22, 2017 | GE Washing Machines
Knocking during wash and spin cycle
I woulds let a repairman look at your machine. Your rubber dampers are broken and your machine will shake itself to bits if you don't address this problem.
Mar 07, 2014 | Computers & Internet
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
