IT JUST WON'T WORK
Possible that the loading is not completing and so does not go into head loading. If the head loads and does not run then it is possible that the optical unit is faulty.
Also it is possible that if there is no response to after loading of disc the fault can be failure in the controller processor board or the loading drive. Try and clean the optical unit and see if there is any result.
SOURCE: Samsung DVD-VR375 DVD Recorder /
Hello [1] Press the ?? buttons to select Factory Setting, then press the [2] Select Start and press ENTER.
Set it to its Factory settings and check. To set it to factory settings get into its Menu Window, Select "Setup" and select factory settings.
ENTER button
The setup settings return to their factory defaults
[3] Press ENTER when Finish appears.
After reset, try to eject function.
SOURCE: Sony RDR-VX525 VCR / DVD
Hello
It has a switched mode power supply [SMPS] regulator inside it. You have located the fuse in itself. As far as fuse is OK, either switching device or mains rectifier diodes and load ressistor should be checked. There is no direct short circuit inside that board, if so fuse will fire up. It is very difficult to an unexperienced person, who is not have sound knoledge in digital elctronics; to rectify this problem. If you are experiecied, go forward. If not, it will be best to replace the power control board. It is available on most of the electronic component spare part shops at your town. There is a number printed on its printed circuit board and it should be noted. The number must be the exact one, if you replace the board. Take out the board from the set, and keep it with you as a sample, when you go to buy a new one. If you are not confidence in this work, never do nothing, and get it repaired by any experienced service personal. OK.
SOURCE: DVD recorder won't format discs or record
check what kind of blank dvd your dvd recorder accept.
