Is it feasible to take apart the transmission on a Maytag Peforma and tryto fix the transmission? I already have everything apart, but can't get the top plastic and other items off of the shaft, so I can access the top of the transmission. (The transmission won't rotate CW to let the drum spin, but works fine CCW for agitation.)
    Genius:
  • 1,028 Answers
Hope you ckd the brake and thrust bearing first if brake doesn't release gearcase won't spin lean washer back against wall turn pulley by hand (can't remember which way) and watch the brake to see if it releases if not BE CAREFUL brake spring has 200 lbs of pressure remove pulley and brake stator ck for rush build up for damaged brake ..no gearcase not serviceable
Posted on Oct 01, 2008
Its not picking up good
well..make sure the belt is on correctly..make sure u empty dirt..carefully tryto see if it is clogged..maybe a hanger..carefully
Dec 10, 2012 | Bissell 3102-0 EasyVac Upright Vacuum
We have a Maytag Peforma Model PBB2255GES Maytag Refrigerator. It has a bottom freezer drawer. We have water pooling under the right front leg of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 29, 2011 | Maytag Refrigerators
Maytag Peforma Series MGD5740TQO Runs - does not heat Cleaned all lint from dryer and hoses
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Dryers
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Need to take out passager drive axle to get alternator our
If you have everything already apart then the drive shaft should pull right out. Some times they pull out hard. Try turning it back and forth and give it a good ****. Make sure the transmission is in natural.
Oct 19, 2008 | 2001 Mazda MPV
Just hooked up new pxc yesterday was working fine today when i tryto open a favorite web site from desktop shortcut it just flashes and does not open . i can open if internet is already open or from...
i fixed this by doing a recovery back to the day before when it started acting up and since i really had nothing on the pc toworry about losing
Sep 14, 2008 | Computers & Internet
Maytag dryer thermostat
Not 100% about this model, but the stat is located next to the fan.
Remove the front cover - insert a flat blade between the lid and front panel approx 4" in from each side to release the clips, lift the lid, remove the front panel (2 screws) fan and stat at the bottom, rest is straight forward.
May 04, 2008 | Maytag PYE2300AY Electric Dryer
Maytag washer is leaking
There are special tool designed to dissassemble this unit although it can be broken down without them if care is taken.
Having the model and serial number would help but be assured that the threading is standard (Rightie tighty, lefty loosy)
Maytag used different designs. Repair depends on the model/serial number. With this information I may be able to step you through the repair.
Knowing the age of your machine would be a plus in determining if repair is economically feasible.
Jan 02, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
