Question about Kodak Cameras
MY CAMERA KODAK EASY SHARE CX7330 IS STUCK ON DATE TIME HOW DO I GET THIS OFF????
I had the same problem.Use the easyshare software and connect to the usb of computer.This is a solution but the switch on the camera (OK SWITCH) is bad.
Posted on Nov 30, 2008
Kodak easy share CX7330 driver
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
May 22, 2014 | Kodak EasyShare CX7330 Digital Camera
Can't change date and time changed on kodak easy
Press the MENU button. Use cursor-left/right to select the Setup tab. Use cursor-up/down to select "Date & Time". Use cursor-left/right to move between fields, cursor-up/down to change them. Press the OK button when done.
Sep 06, 2011 | Kodak Cameras
Battery problems
The camera is probably defective. Warranty?!?
Unless you have put the batteries in wrong or not used fresh ones!
Apr 24, 2008 | Kodak EasyShare CX7330 Digital Camera
About battery door broken in Kodak CX7330
I've got 16 of these cameras and had to replace the door on 3 of them. (I'm a teacher)
it is quite simple, but there are little tiny screws and some dexterity required!
to replace the battery door, you need a super small screwdriver (I've used both an eyeglass size and the screwdriver that came with my son's tech deck!) . you'll have to unscrew all of the small screws that hold on the back of the camera. remember which screws go to which hole - because some are longer than others. once the screws are out, you'll have to gently pry off the cover. carefully - you dont want to crack the camera case. you'll also want to be careful not to touch the sensor, which will be exposed with the case off.
NEXT you;ll have to pry the little spring out of the battery door to actually remove the old door. you'll probably have to use a screw driver to pull the spring on the new door back enough to fit back into the holes. that's really all there is to it. replace the cover and the screws.
Feb 11, 2008 | Kodak EasyShare CX7330 Digital Camera
Kodak easy share cx7330
I have the very same problems as listed above. My friends have different models of the Digital Cameras and none have these problems like the CX7330.
Feb 10, 2008 | Kodak EasyShare CX7330 Digital Camera
I need a new battery door do you know where I can purchase this item?
Try ebay. They have it all. You might be able to find a camera that doesn't work but is being sold for parts. I see stuff like that on there all the time.
Nov 28, 2007 | Kodak EasyShare CX7330 Digital Camera
Please help
non scarica le foto della memoria interna
Feb 03, 2007 | Kodak EasyShare CX7330 Digital Camera
Cameras Logo
52 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
