Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
Belling 100df dual fuel cooker
Mislaid instruction manual. Help! what is the difference in cooking times between the convention oven and the fan oven, i keep burning everything!!
  • Anonymous Dec 25, 2008
    I have lost the manual, can anyone help
  • 833 Answers
Generally, reduce both the temperature and cook time 20% when using convection.  350 F becomes 300 or so, for instance.  One hour becomes 45-50 minutes.
Posted on Dec 04, 2008
Difference between a convection oven and a conventional oven
<span>A convection oven is equipped with a fan to speed the circulation of heat around the food, thus cooking it faster and more evenly than conventional ovens. <br /><br />Conventional ovens rely on radiant heat that rises from the bottom up to the top of the oven. Convection ovens cook foods approximately 25% faster than conventional ovens, and the oven temperature can be reduced by 25&deg;F for most foods. <br /><br />No special cookware is required. Just like conventional ovens, convection ovens can be gas- or electrically-heated. As with any major appliance, it is always best to carefully read the manufacturer's guidelines and instructions for operating the oven.</span>
on Apr 04, 2011 | Microwave Ovens
There is no heat coming out of my fan oven, a Belling Countrychef 100df Range Cooker. The fan comes on and the light goes on to show it is on but there is just no heat ! It is about 7 years old. What is...
If the fan is working o/k, then it is sure to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 17, 2010 | Ovens
I am in need of a customer instruction book for this item
Apr 28, 2009 | Cook's Essentials Cooks Essentials Arome...
Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section.'s-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
613 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
