Question about Music
Yamaha Clp 560 does not power up.
I may have, inadvertently, left it on. Now it shows no sign of life. Fuses look good. Burned out power supply? Any help greatly appreciated.
  • beaniedette May 05, 2009
    I have a similiar problem where the Zoom H4 does not power up even when replacing the batteries.
3 Suggested Answers
  • 5603 Answers
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
SOURCE: Hi, My Peavey Classic 50/50 has power (leds are
I had checked the fuse for the heater circuit and found that while it was testing on a low ohm check meter - it was not sufficiently handling the
full demand of the circuit - I put a bypass on the fuse and found the problem. The fuse appears to have been previously replaced with
a type not original - the original was a ceramic case fuse 10A.
I appear to be operational
MB
Posted on Dec 28, 2009
No sound on my Yamaha Clavinova CLP-311
Try these steps:
  • Perhaps inadvertently, there is a MIDI settings are changed.
    Setting LOCAL-ON must be in the ON position.
    Do this (see Figure 1):
  • Connect AUX OUT (at rear panel) to an external amplifier. If the sound is heard, the damage was CLP311 power-amp.25893993-xykdzr1cdriwl1tmr4ngy0qt-3-1.jpg
Oct 05, 2015 | Yamaha Music
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
I had Mackie th15a 110vac and it had busted fuse, when i replace it when a new one it got busted again...i plug the power cable to 110vac without a regulator. what would be the possible problem in the...
If fuses keep blowing there clearly is something wrong with the power amplifier. You can start by getting access to it and doing a visual inspection for signs of overheating or short circuits but then it will be necesary to check parts and eventually you will be able to isolate the defective part(s) and repair it.
Dec 26, 2013 | Mackie HD1801 Powered Subwoofer (1600...
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
Hi,help me,when i power my soundcraft efx8 on,it only flashes times and times(the level meter and signal chn lamp),as it cannot power on,please give me the solutions for this.
It is something that will be localized to the power supply board. But double check to make sure the phantom power is switched off.
If you are up to opening it up, look for loose connectors, check fuses, look for bulging filter capacitors- these need to be replaced and they may be the only real casue of the problem. The caps may not show visually, but if you try carefully powering the board up, a faulty capacitor will sometimes feeling like it is boiling inside- at that point- it is boiling and shorted out. Replace with same working voltage or one step higher, and same capacitance value.
There are sometimes physically larger resistors on the power supply board- these sometimes double as fuses- intentional and unintentional. Check them for continuity, they will not show anything physical if they fail.
Bad solder connections can also cause problems, as can faulty rectifiers in the power supply, even voltage regulation devices can fail. These however do show physical signs of failure in many cases.
Have patience with this as it may be simple, or it may not be simple.
Apr 06, 2012 | Music
Light is dead all fuses are good.. Maybe bad transformer ?
Probably NOT the transformer as most of these have switching type supplies. A Chauvet unit I have would not light and the problem was the socket for the Halogen bulb. The socket had burned and the contacts were so burned they would not contact the bulb. Worse, you can't even see the problem as the socket is ceramic and has a mica like cover. Replacement of the socket fixed the problem. In the Chauvet unit they had a very cleaver lamp power supply. That threw me off because there was no voltage at the socket... until I put the Oscilloscope on it... then there were tiny spikes. It turns out the supply sends tiny spikes out and IF the lamp is there and contacts are good, the supply senses the load and the feedback starts driving the supply to full output. I wasn't able to see the burned contact until I uncapped the socket. Just maybe you have a similar problem. These 250 watt Halogens with the tiny pins carring 11 amps just are ******* the contacts in the sockets.
Aug 05, 2011 | American DJ Supply American DJ Accu Scan...
My Yamaha Clavinova CLP-350 lost all sound. Prior to this, middle C started to have a tin-like sound. I live in South Central PA and can't even locate someone who repairs Yamaha keyboards within 50...
Here is service manual for CLP380 which should be close to your unit.
http://elektrotanya.com/yamaha_clp-380.pdf/download.html
Scroll down to get manual and click on it to download. Ignore other download links.
First thing check your power supply voltages.
Aug 03, 2011 | Music
Buying a used Tascam 788. P.O. lost the power supply. How can I get a replacement? Couldn't find anything on TASCAM site.
Hi, Provided there is a tag on the back showing the units model number, on that same tag should be the power requirements for it-buying a universal power supply, or even a used working one to another piece of equipment is acceptable as long as the polarity is the same. Polarity is located right next to where the power supply plugs into the unit. It will be a " circle with a dash inside it with a line connecting to a C looking symbol with a line coming out of it connecting another circle with a plus sign inside. " that is a typical outer ground/inner positive marking. a power supply will be marked the same. If they match the polarities are the same. Next make sure the power supply says the proper DC voltage and Milliamps or amps-Ma/A example: 2400Ma, 2.4a. I hope this helps and thank you for asking FixYa, good luck and don't forget to write back and let me know how I did, Prodzilla.
Apr 23, 2011 | Record Tools Tascam Dp02 8 Track Digital...
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Music Logo
117 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
