Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
McCulloch generator stops after about a minute
Generator starts fine and runs fine for about a minute or so and then starts to die a couple times and then stops completely. Let it sit for a short time and same thing happens again. Took drain loose from carb and fuel flow seems to be OK. Loosened gas cap to make sure it wasn't a venting problem but that didn't help. Oil level is OK. Is there a way to bypass the low oil shutdown to see if it may be causing this?
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Posted on Jul 12, 2010
Found the problem to be in the low oil shutdown. Not sure if it is the electronic switch mounted on the outside of the engine or the sensor inside the engine. Have ordered parts but still waiting as they have been on back order for over a month.
Posted on Nov 01, 2008
What should i set the valves at for a Mcculloch 11HP FG6000 Portable generator
Posted on Aug 27, 2010
Had a similar problem with my 800E for the camper. The first thing I did was move the wife away from it. Little thing hates her. Haven't figured that one out yet. Now your big boy probably doesn't have the sort of choke my little guy does, but sure enough if I didn't have all the same running troubles as you. I just had to tweek the choke a bit and he runs like a little champ. Something to think about anyways.
Posted on Oct 31, 2008
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
It sounds like it is starving for fuel. You probably need to rebuild the carb.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
My generator is a briggs and stratton 7kw prowered. connected to full propane tanks. i have not had any problems with the generator until this past weekend. the generator starts up fine, and then once...
You have a fuel delivery issue that can be dealt with by cleaning carb or replacing it. If you do replace carb has to be adjusted to the motor.(idle, mixture)
Sep 03, 2017 | Briggs & Stratton Briggs Stratton 7 kW...
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
McCulloch Generator model FG6000mk 11hp run good until I turn on generator then stop running do you think the generator bad and can it be rebuild ?
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
Jun 12, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 5700, 11 HP Starts easy with 2 pulls and begins running fine. Then it start dying and back fires,revs up and down, back fires. Then will run normal for a few minutes and will start revving up...
Sounds like you may have a wire shorting out. Check all ign wires and make sure one hasnt rubbed through. Maybe take off your front cover and make sure something isnt shorting out your coil contacts. Hope this helps
Nov 02, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Shorted out generator??
they do smoke if its petrol lol joke sounds like a short circuit check the connections
Jun 08, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Mcculloch generator 5700W 11 hp
Sounds like your choke is not closed correctly when you first start the genset. Remove the air filter and look at the throttle plate. It should be closed with a hair line gap. With your finger you should feel very little play on the throttle plate. As you open the choke, you should be able to open it all the way once the engine has reached a hotter temperature. If the engine is still cold and your opening the choke all the way, it will try to die out.
Feb 09, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
1,298 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
