Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
My hp presario v2000 battery/fan does not work
My computer battery does not work but the battery itself works.....my roomate has the same computer as me and we switched batteries and my battery worked in her computer yet her battery did not work in mine....i think that it might be a problem that my computer has...also my fan stopped working...its doesn't give air no more and i didn't do anything to it...it shuts off when it overheats what should i do?? and can this be a cause of a virus?? i've hp pavilion dv2601tu notebook. my notebook's fan is not working.
  • HP Master
  • 4,338 Answers
Viruses will not cause these symptoms....
First of all, do not keep running the laptop in that fashion, the CPU will overheat and die on the unit. Have it serviced for the fan problem. The circuit that controls the battery also may be bad. In any case , you need to have it serviced.
Please remember to rate all users who assist you for free :)
Posted on Sep 30, 2008
How can i change the CMOS battery of my Laptop Compaq Presario V2000?
Here is the location of the appropriate Service Manual - you will have to partially disassemble your computer to reach the battery and replace it.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Sep 19, 2012 | HP Compaq Presario 2200 Notebook
COMPAQ V2000 service manual
There is also a BIOS battery but this would not stop it working.
Feb 14, 2010 | HP Compaq Presario V2000 Notebook
Power light is off when plugged into wall-power (and battery removed). Power adapter by itself is working
It is normal for the power light to be off if the battery is removed. Are you able to use the computer at all?
Jan 18, 2010 | HP Compaq Presario V2000 Notebook
Screen is black, but fan runs. Then computer cuts
This most often means you have a bad cpu or motherboard. When the bios does its post checks it looks for issues and will shut the pc down if all the devices are not funtioning correctly or the CPU reaches critical heat.
Dec 29, 2009 | HP Compaq Presario V2000 Notebook
Laptop just cuts out
update your laptop bios go hp.com see your proper model number of your laptop download new update bios and install it.
Mar 17, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 having problems powering on
hi!
i'd say first try a known working ac adapter and if that Working AC adapter works and the system detects the battery well, then it could be the ac. If not then try to borrow a working battery to get your final conclusion. if the working battery still doesnt work properly, then it could be the system motherboard. If battery and ac adapter (working) are not available, then check the BIOS and see if it really doesnt detect the battery. try flashing the BIOS and still if that fails, then replace the battery.
hope this helps!
Regards,
Karlox
Jan 23, 2008 | HP Compaq Presario V2000 Notebook
The fan most likely needs to be replaced. When the computer overheats as a safety feature it shuts down. If you do not know how to replace the fan take it into a repair shop. The does not seem to be the problem.
Oct 25, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
