Question about Panasonic PT-52LCX65 44" HDTV
Thick Black Line Down Middle of TV
When I switch from HD to standard definition channels, I get a thick black line down the middle of my screen. When I switch back to HD, there's no line. If my TV is off and I turn it on a standard def channel before and HD channel, there's no line. I tried changing the cable box and that didn't help.
  • StickE25 Nov 09, 2008
    Same problem.
Does this only occur with one input and/or does it occur when using HDMI/component cables.
if so, try getting a new HDMI cable. I have the same problem with PS3...and im about to order a new HDMI cable.
Posted on Oct 08, 2008
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Thick black line running down the middle of my screen
May 13, 2010 | Soyo SYTPT3227AB 32 in. LCD TV
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Thick Vertical Line
the power supply is defected a capacitor filter is leaking.have a tech repair your tv.good luck.
Mar 01, 2010 | HP PL5060N 50 in. Plasma HDTV
My Bush tv NR Itv 2101 on channels 1 & 4 picture is fine but channels 2,3, & 5 has a black band 1 inch deep top and botton. All channels say 4.3 so can't be that, any idea's. regards JM
it is because the channel is being brodcast in hd and not just digital. it is an unfortutane side effect of the dtv convertion, all brodcast are now digital but not all are high def, if you had a high def tv and were watching and standard definition channel it would have thick black line on the left and right because the image does not fill the dislay
Aug 14, 2009 | Televison & Video
There is a thick black line down the middle of the screen
Aug 11, 2009 | Hyundai HPT-4250 Television
Black line in middle of panasonic plasma screen
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Panasonic PT-52LCX65 44" HDTV Logo
273 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
