Question about Mitsubishi WS-48513 48" Rear Projection Television
GREEN LIGHT BLINKING AND TELEVISON WILL NOT RESET ON MITSUBISHI WS-48613
MITSUBISHI WS-48513 TELEVISION WILL NOT COME ON
GREEN LIGHT JUST KEEPS BLINKING. What is the problem.
  • 3 more comments
  • gordonsoule Oct 09, 2008
    Blinking green light will not stop, have not been able to solve usings owner manual. Blinking for three days, have unplugged and then reset , no luck
  • Anonymous Oct 31, 2008
    Exactly the same problem. Where are those bad componets located? I am a component engineer and can fix it myself if it is soldering problem
  • cheftishhill Nov 24, 2008
    GREEN LIGHT BLINKING AND TELEVISON WILL NOT RESET ON MITSUBISHI WS-48613 problem, and notify you when a new solution is offered.
  • tblack1950 Dec 07, 2008
    green light will not stop blinking
  • Anonymous Dec 09, 2008
    bought this tv 1 1/2 years ago. blinking green light and no picture, tv will not reset. I paid alot of money for this tv. I will never buy another mitsubishi tv again
    Problem Solver:
  • 39 Answers
Bad solder on the vertical ic401, or bad solder on the yoke.
Posted on Oct 02, 2008
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Power was off
You need to replace 4 capacitors on the DM board. It is located inside a metal box on the left side of the set, looking from the rear. The original parts are 1000uf 16v. You will need to install 1000uf 25v or 35v. They are located at the top of the board and are green colored.
May 28, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
TRY TO GET TO THE MENU, SETUP, AND EDIT YOUR SETUP SO EVERYTHING IS DEFAULT. I TOOK A 2001 50" HOME LAST NIGHT, MY SLEEP TIMER LIGHT ON THE FRONT, BLINKED FOR A FEW MIN. THEN, YOU CAN TURN IT ON AND RESET.....HOPE IT HELPS.......????
Dec 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
meeh.shell@yahoo.com
Oct 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green Power light keeps blinking and set won't turn on
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Feb 06, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Turn tv on green light keeps blinking wont reset
Verify Model # off back of set and mo / yr built......critical for
correct solution....For example, if your # ends with.....13, then
a DM module repair will be needed...replace four capacitors...
1000mf 25v 105 degree.....If different model = different solution
....................................T.
Dec 14, 2007 | Mitsubishi WS-55809 55" Rear Projection...
BLINKING GREEN LIGHTS IN FRONT
Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030..if they are ok then the DM pcb itself is bad part # 934C067002
Nov 27, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-48513 48" Rear Projection Television Logo
614 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
