Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
No driver why my macbook air cannot detect samson gtrack mic.?
  • gen4ever Apr 04, 2009
    i'm having the same problem using macbook air, nothing happen after plugged in the G-Track, and i couldn't use it in Garage Band as well.
    help~~~
  • PBandJ
    PBandJ May 11, 2010
    Maybe it's defective? Did you try it on another computer?
  • 4 Answers
What operating system are you running on? The manual says it requires mac os x - try that?
Posted on May 14, 2009
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
I purchased a R31S Samson Microphone and it cant be detected when i plug it in to my computer microphone jack. What is it to do?
A dynamic mic connected to the your computer's mic jack is an analog connection. So your computer won't give a notification that there's a mic connected. However, you can view input levels through the default windows mixer of your sound card or any program or application installed on your computer that has the capability. Had it been connected through usb or firewire, it would be digital and you wold be notified that the device had been detected via device drivers etc.
Hope this helps
Apr 09, 2011 | Samson R31S Microphone
I use the samson C01U usb microphone on my macbook pro for almost 4 years. Now I recently updated to mac os 10.6.6 (latest update) and Samson soft pre won't start up anymore. I can't configure the mic...
1. Try reinstalling the softpre software.
2. Read through their FAQ at: http://samsontech.com/products/productFAQs.cfm?prodID=1810&brandID=2
3. Contact samson directly at audio@samsontech.com with your problem.
Mar 03, 2011 | Samson C01U - USB Studio Condenser...
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Problems with samson g track usb mic
sounds like your recording volume is too high, and its "clipping"
Mar 03, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Many Problems with Samson G-Track or not?
Hi.  I dunno if yur using pc or mac but with a mac yu need to adjust the mic settings on the comp. For the static its probably your set up or as i said in another guys problem, the usb cable given with it is **** so try using another one from a printer or wtv to see if that makes a difference for you. Also if you are recording just through the mic i find that it seems to only work well when the input is on line and not inst/mic. Hope this can be of some help. Its a great piece of kit once you get it working well.. Goodluck
Jan 16, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Imac-samson-gtrack mic compatability
From the Samson Audio website...
"Ideal for the traveling musician or the project studio, the G-Track ships with a desktop mic stand, swivel stand mount, USB cable and all the cables needed to connect any musical instrument with a standard 1/4" or RCA output. The G-Track ships with Cakewalk's Sonar LE and works brilliantly with Apple's GarageBand."
If it states that it works with GarageBand, I would say that it would work on a mac.
Nov 29, 2008 | Apple iMac 24" Desktop
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
319 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
