Question about Carrier 38CKC036 Air Conditioner
Carrier Product # 38BRC042320
I recently found out that my builder had used older model water heaters (1996) in our house built in 2000.
IAfter replacing one Carrier condenser in only 5 years, I am trying to find out how old the remaining Carrier condenser is. The serial number is 1800E29784 and Model number is 38BRC042320.
Marilyn Keys
keys@gte.net
    Scholar:
  • 121 Answers
This unit was manufactured 1/8/00 and is a 4 1/2 system
Posted on Sep 30, 2008
Water heater leaking
I would call home depot and ask how they handle their warranty with Rheem. Contact your builder and get the information of the plumier that installed the unit he should be able to give you the pluming supplier where he purchased the heater.
Jan 20, 2014 | Rheem Water Heaters
I bought a brand new house and the gas water heater seems to be stuck in vacation mode.
Copy following link to troubleshoot by type of gas control valve, instructions how-to-light-water-heater, including error codes etc:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
To reset the intellivent gas control, press and hold both arrow buttons for about 5 seconds
This water heater requires pilot flame. Look through site glass and upward (or use mirror) to see if pilot is ON and burning clear blue flame and not lazy yellow flame.
Check that gas shut-off is parallel to gas line:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Check if outlet has 120Volt, and that polarity of outlet is correct. Power vent water heaters require correct polarity: use circuit analyzer. Check if there is ground continuity between ground and manifold tube (center tube that connects between burner and gas control valve).
Scroll to top of same link to read about FV system and air intake cleaning. Must have good supply of incoming air.
Same page half way down has troubleshoot section for pressure switch testing, blower troubleshoot etc. The pressure switch and blower communicate electrically with gas control thermostat to determine when to release gas to burner where pilot ignites gas, causing poisonous combustion by-product to vent outdoors and help nature.
This model has thermopile instead of thermocouple. Basically thermopile is several thermocouples. When heated, thermopile generates enough current to run small electronic circuit inside gas control valve. This circuitry is very common in hvac units but fairly recent to water heaters. Advantage is error code troubleshoot and more optional controls, for example future response to in-home zwave remote controls and home automation
Get model number and brand from label on side of tank and post question on pro water heater forum with list of what you have tried so far.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Call plumber to bleed air out of gas line and check gas pressure.
May 28, 2013 | Water Heaters
Water leaking out
1) Copy following link for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
2) Feb 2013. Add comment and describe product and add if this is new installation or older installation that recently changed.
Feb 23, 2013 | Water Heaters
Richmond 5v40-36f
1) My search does not show that product exists, or existed before the internet.
Maybe that product only exists on fixya.
Or the water heater is older model number from Rheem., aka Richmond, Ruud etc.
Or fixya picked up a model number from a question, and the person asking question did not copy model number correctly from label on side of tank.
It might also be older manufactured home gas water heater.
Feb 07, 2013 | Audiovox Water Heaters
We need a dodge wiring diagram 1974 chasis for a vouge motorhome
since Vogue made bodies for dodge as well as Ford,, the diagram for the Ford or Dodge portion itself would be in a manual that addresses that make and model,, for the Vogue end of it, you will need to contact them for the conversions they use for each as per Jim... The Vogue II was built from 1985 till 1987. Then the Vogue III was built in 1988 and some 1989's Then came the Prima Vista built for 1989 till 1996. Then the Vogue 5 come along from 1996 till 1999. If you see a Vogue with a later date than 1999 it was still built in 1999 but sold in 2000 2001 or 2002. There was no Vogue built after 1999. Vogue motor coaches were built from 1973 till 1999. Cosmopolitan's were gas jobs built and sold for a lot less than the Vogue II. A much cheaper built coach. You might see a Vogue 6. Featherlite started to build 3 of them in 2000 but never finished them. 2 Were bought and finished by independent builders. Please rate my response as I am trying to up my percentages Thanks
May 27, 2011 | Dodge Ram 2500 Cars & Trucks
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
I have a three year old home with a noritz tankless hot water heater. It's leaking and the plumber says the flue was plumbed incorrectly which invalidated my warranty. So, apparently I need a new tankless...
bull ****! . If the heat exchanger is leaking, it should be under warranty. If you have and improper installation that should be the responibilty of the builder or his plumber. You may have some labor cost, but not the entire cost. contact your builder
Feb 04, 2010 | Noritz 6.3 Gallon Residential Tankless...
Carrier Central Air Conditioner - Specifications
your specs should be on the rating plate volts, amps,refrigerant factory charge, etc...
Aug 09, 2009 | Carrier Heating & Cooling
There a loud noise coming from the bottom of my unit
Hi There,
Check the fan drive belt & motor. Hope this helps and thanks for using FixYa!
Mar 30, 2009 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
808 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
