Question about Kirby Ultimate G Bagged Upright Vacuum
Not real sure what is wrong with my kirby.
I t sounds like it is working fine but once I lower it to the correct level it sounds like it is working to hard and the light that show it is spin turns off. I know I am not lowering it to much. I have used it before at the same level and now once it barely touches the carpet it starts to have problems.
    New Friend:
  • 161 Answers
I would say to replace the belt for the brush....kirby's have been known to go through belts.....also when i owned one within a year i think i went through 7 belts....try that and let me know what happens. the belts easy to replace.
Posted on Sep 30, 2008
Kirby sentria 2
Make sure the belt is the right size.. It should be very very tight.
Apr 16, 2014 | Vacuums
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
How do i engage belt
you need to make sure the belt is on the roller correcty, make sure is at the red position when putting the part back on with the belt on the hook, push the pedal to highest (off the ground) position to ensure you put it on correctly, then turn the fixing clip thing to secure it, then once its on turn the panel around to green position, belt will be back on, once you get used to it you'll be ok, if you know this already I apologise in advance :o)
Jun 28, 2009 | Kirby G4 Bagged Upright Vacuum
I shampooed my carpet and later that day went to use the Kirby Sentria and it wont turn on... it has always worked fine up to this moment, what could be wrong?
there is a safety feature on the kirby that if there are no attachments on the front or the side it will not turn on. check and make sure your attachments are properly on the machine
Apr 21, 2009 | Kirby Heritage II Vacuum
Do i want the green light on or off on kirby upright
It has nothing to do with the green light. Green light simply indicates that brush roll is spinning. If there is no green light:
1 - belt may be broken
2 - Improperly installed nozzle
3 - wrong brush roll is installed
Properly adjust the nozzle - turn the Kirby on. Keep lowering the nozzle till it touched the carpet and you will hear change in sound. Then lower it by one more click.
Rocky
(GoodVac.com)
Mar 30, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How to change carpet level for Kirby Heritage II? at highest level and can't lower it.
step on the hight adjustment on the left side of the head. If you need anything for a kirby or help feel free to call 970 824 3772
Mar 26, 2009 | Kirby Vacuums
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
70 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
