Question about Dryers
Dryer ctd80 f10
I read your problem solver so i took the back off the dryer when i took the back off for the thermostat water poured out and the element's had snapped and were corroded so my dryer will not heat up can anyone help with a reason or solution to the problem
thanks its its less than 2 years old cost me 349
    President:
  • 1,462 Answers
There is a small duct from the condensation chamber to the pump housing and this is blocked.
Posted on Oct 01, 2008
WERE IS THE RESET BUTTON ON HOTPOINT DRYER CDT 80
Not sure if all dryers have a thermostat reset. You can check your model (which might be CTD80 and not CDT80). Usually it can be reset if there is a small hole in the middle of the device where you can insert a tooth pick and press it.
Location of thermostats is at the back. Make sure the power chord is unplugged from the wall.
See this youtube video.
how to replace Hotpoint tumble dryer thermostat
Sep 01, 2014 | Hotpoint Dryers
Pressed reset button on left hand therm0stat dryer runs but still error code f10 elements not getting warm
I found this, an answer already posted on Fixya.....
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Dec 12, 2013 | Hotpoint Dryers
Hotpoint ctd80 power gone, not fuse problem, is it thermostat?
Open up panel where the power cord goes into the machine, plug it in and do a voltage check. Also look for possible burned wire at contact connection or wire came off.
Mar 25, 2009 | LG DLE7177 Dryer
F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
I have a hotpoint ctd80 showing error f13, have cleaned all the filters, and cleared the water and still it doesnt clear error on the low heat setting
F13 indicates the rear thermistor is open/short circuit, this is part of the heater circuit. it is akin to a thermostat, but there is more than one!!
Hotoint recommend you call an engineer..
I am assuming that this is a lcd tumble dryer.
Plz leave feedback.
Ta.
Dec 10, 2008 | Dryers
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ctd80 hotpoint dryer error code f10
Apparently a common fault on these indicit based driers.
it worked on mine
Oct 08, 2007 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
