Question about Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax
Scanning Hi. We have an NRG445 machine. We used to be able to scan to email and recieve it in about 30sec. Suddenly it stopped doing this. Sometimes we get it immediately, other times can take up to 6 hours, other times we have not recieved it at all. I assume it could be as simple as a setting. Can you assist
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Check the Mail Server IP or name and press the connection test.
Sometimes it is better to change the Mail server address.
Good luck and please rate me, thanks.
Posted on Feb 06, 2009
My fujitsue fi-6130 stopped automatically scanning both sides
You can try a 'hard reboot' of the unit by unplugging it while it is running, wait a minute or so and then restore the power.
With most electronics this forces a 'self-diagnostic' program which might fix the problem. Another option is to delete and them reinstall the software with a disc or online. Make certain that you have your machine set to automatically check for updates if it is connected to the Internet.
Jul 22, 2014 | Fujitsu fi-6130 Flatbed Scanner
How can I email a document from xerox copy machine through my laptopp
The best way to email any document from any printer is to have a scanning program that can scan from your printer/scan/copy machine. If your printer only has printing capabilites then it is impossible to capture the printed document back to your laptop.
The first step is to check to see if your Xerox copy machine is a model that includes printing/scanning/copying capabilites.
If it does, then install the scanning program.
Once installed, scan your document, save it to a place you remember on you laptop, then email it using your favorite email program, such as hotmail or yahoo.
hope this helps, if not let me know.
Feb 12, 2012 | Dell Computers & Internet
Hi, I have preveously send fixya.com a problem case as follows :"I have a 2007 Kia Carens (Rondo) 2000cc with 4 speed automatic transmission, sometimes the gear stuck on 1st speed and sometimes it...
Hi.
About your chat with TDISLine, you can add comments to the chat. You will be notified by email, and the expert will answer.
You can find the chat either in your Profile list (here ) , or in TDISLine chat list (here)
Regarding the problem, refilling transmission fluid is only forst step in troubleshooting.
The problem is often either the shifter console, the transmission control unit (TCU computer module), or a faulty transmission box itself.
Next step in troubleshooting is doing a code scanning. An OBD II code scanning can be done at home or at any garage, but to do a complete code scanning that includes scanning of transmission control module you need a Vag Com tool. This is expensive and it is available only at the dealer place or at a VW/Kia authorized garage. Scanning is usually billed half hour labour, and it is not expensive.
I wrote an article on same problem here. Disregard the part on "stuck in park". Article was originally written for Mercedes. Things are not too different with the Kia carens tranny.
Job is carried doing in order:
  1. OBDII code scanning, then TCU scanning.Testing for fault indicated in codes if needed.
  2. Bleeding and refilling transmission fluid.
  3. Removing cover and checking shifter lever state and conditions.
  4. Checking for tranny fluid leaks in vacuum system.
  5. Testing the TPS (throttle position sensor).
  6. Checking transmission shift solenoids (in valve body), wiring and TCU operations.
  7. Checking the transaxle itself for malfunctions.
Job bill may start from one or two hours garage if you have some silly problem like faulty TPS, and if problem is spotted at start. Repair can get very expensive if you have for example a defective gearbox.
Regards.
Ginko.
Nov 04, 2010 | Kia Rondo Cars & Trucks
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
Suddenly stopped scanning and now won't copy or print b/c keeps saying it's still scanning. Canon mp830. Scanning Wizard starts but just dies in the middle. Any button I'm not hitting or solution you can...
Any lightning strikes locally?
You can try to reset back to factory by removing cartridges and head.Power off unit ,then unplug for 45 minutes.repower and install all.
Do a nozzle check and see what happens.
Aug 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Kyocera 3035 under res. i get e023
The KM3035 requires a second network card for network scanning. then use the scanfile utility on the client machine / server to recieve the jobs and dump in a shared folder
Apr 01, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Xerox 4150 not scanning to network
I need more information, like is it scanning using the SMB protocol or FTP. Are you using active directory, etc. Usually, when they just quit, it is due to a Microsoft security patch, or a software firewall having been enabled. If you're sure that it is neither of the above, try browsing to the Xerox via the IP address, go to the properties tab, services, network scanning, file repository set-up, and see if the login name used for network scanning is qualified: (i.e. - domain\username) Often, in a business environment, that will help.
Mar 20, 2009 | Xerox WorkCentre 4150 Black and White...
Scan to computer
Your machine has Vista supported print drivers?
This is where you can go for the Print Drivers.
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Scanning: first your Machine needs network scanning enabled: (if you can scan with other PC's, dont worry about this) this a key you will get from your dealer..
as for scanning there are a few options:
Scan to email which you can scan through the network to your email using your email server..
Scan to desktop
you can use Sharpdesk a program that will come with the machine if Scanning is enabled? which now is available for vista, your local sharp dealer will have(not sold in stores)
or you can try the Twain Scan (LAN).. which you can find on the sharp web site listed above..
Nov 13, 2008 | Sharp MX-2300N Color Copier
Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax Logo
57 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
