Question about Neff U1661 Double circotherm super Electric Oven
Neff Oven I have a Neff Oven, both ovens worked fine, then the bottom oven light blew, so I changed the bulb and all of a sudden a loud "POP" sound happened, and both ovens went dead. I went to the fuse box and it had tripped out the circuit, so I pushed the switch up and turned on the ovens. The top oven was working fine, but the bottom oven wasn't, also the digital display i.e. clock and any lights for the bottom oven do not work. What is the problem?
  • Neff Master
  • 3,463 Answers
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Posted on Nov 26, 2008
  • 25 Answers
Had the same problem. Read that controller board needed replaced. 200 plus vat plus fitting. Decided to strip down and remove controller. split the circuit board off and discovered a number of blown tracks, Managed to solder copper wire across pins, reassemble and working fine. Probably saved me a new oven
Posted on Jul 28, 2013
My oven light is replaced with a new one but still not lighting up
Bulb socket must have a problem. The bottom contact is not touching the bulb. You may need to replace the socket if you can't bend the bottom contact back into place.
Feb 18, 2015 | Neff Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Neff double oven u1442, main oven thermostat light does not work even though oven heats up. Is there a fix?
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Mar 18, 2011 | Neff U1452 Double circotherm plus Electric...
Frigidaire gallery stove, oven not working,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Feb 07, 2010 | Neff B1421 Electric Single Oven
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
U1721 Strange Problem
could be a clock fault - try bypassing the auto function on clock.
otherwise, check the terminal block where mains is connected. these quite commonly burn out
Jul 06, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1661 Double circotherm super Electric Oven Logo
963 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Neff Oven Expert? Answer questions, earn points and help others
