I am unable to print because 2 new cartridges are not lighting up that they have been changed. I have tried other cartridges there without success in printing.
The solution are refiling the printer
Posted on Sep 30, 2008
I put new print cartridges in my 960c printer. They are hp 78 for color and 45 for black and white. my orange ink light will not stop blinking. It is not printing
I have an HP DeskJet 1220C that has been working fine for two years now. All of a sudden it can only print in pink and black. It is driving me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
Aug 25, 2011 | HP DeskJet 960c InkJet Printer
Black cartridge (HP21) will not print or prints faint 2mm strips (like a pedestrian crossing) of a broad black test piece on my HP Deskjet 2180 Desk. Colour (HP22) is OK. Cleaned cartridge manually per HP...
This type of cartridge has the printing head in them - the possibility that all 3 ones are clogged is extremely low. If you get a bad printing with them it's because the heads are incorrectly commanded - either the pin array that transfer the command is damaged and they will have to be cleaned and fixed or the processor of the printer is dead, and the printer with it.
Jul 09, 2011 | Office Equipment & Supplies
Error code 0xc19a0023
I went crazy trying to fix my HP D7560, days and days of print ink failure, unable to align cartridges, until to clean print heads. My symptom is that the black ink started to print only in a light gray. I tried everything from running Tools, changing to new cartridges, even buying a new print head (which was not genuine HP, they don't make them anymore, and the new print head would'n't complete in diagnostics without error). I love this printer and didn't want to part with it. So I searched for days and tried many solutions without success. Until I found this one last solution - it my last ditch effort. The solution is to get a bowl of very hot water (not boiling), remove the print head from the printer and place the print head directly in the hot water (sounds risky! but I did it). I watched as the bowl filled with black ink. The instructions said to let it sit for 5-10 minutes, but I couldnt' believe the amount of ink that poured out of the print head. So, I kept replacing the water and shaking the print head carefully in the water to loosen the trapped ink. I repeated this step (replacing water) until it was no longer producing black cloud of ink and water was fairly clear. I carefully dried the print head with a paper towel, let sit for approx 5 minutes to dry some more, shook it vigorously a few times to shake out any water, and then lastly hit it with a blast of compressed air to ensure all water droplets were gone. I put the print head back in, re-inserted the cartridges and the printer ran through diagnostics automatically - aligning cartridges and printing a test page - it was BEAUTIFUL!!!! Until I tried this, nothing worked. I'm hoping this solution will help others. Good luck.
Feb 15, 2011 | HP Photosmart D7560 InkJet Printer
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
Error1102 occurs after new ink cartridges are installed
To clean the NVRAM, please follow the steps given below:
1. Press the "Up-Arrow" button and "Menu" Buttons Simultaneously.
2. Press the "Down Arrow" button until the LCD displays "Clean NVRAM."
3. Press "Select." The LCD should display “Success” or “Failed.”
If it is successful, please try this printer self-test by following the steps given below:
1. Press the "Menu" button.
2. Press the down arrow button 9 times until the screen displays "Print Test Page."
3. Press the "Select" button to begin printing the self-test.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 21, 2009 | Lexmark P4350 All-In-One InkJet Printer
I have a HP 7410, every time I print I get three error messages. First one is "New HP Photo Print Cartridge successfully installed". Second one is "New HP Tricolor Photo Print Cartridge successfully...
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find the hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Let me know if this helps.
If it doesn't, I will research it further. If it does please rate it.
Joe
Nov 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printing/ink cartridge
hi
your printer is not detecting the cartridge, see the pins/connections where the cartridge gets contact, if these are conteminated, clean them. also make sure that you intalled the cartridge after removing its protection seal.
gudluck
Aug 29, 2008 | HP DeskJet 920c InkJet Printer
Print cartridge in right stall not supported.
As a refiller, I've seen this many times. Usually it happens in the multifunction machines. If you put that cartridge in a stand alone printer, it will work good. HP all in ones blow a resistor in the cartridge making it useless to any all in one machine. Sadly, it is time to buy new.
Mar 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
jasbo
jasbo
