Konica 7040, use as network printer?
Hi, we had a Konica 7040 donated. the copier tech told me he couldn't get an IP address on something so old, and if he could the network card would cost almost a thousand dollars. Is this true, and is there another way to print from computers to the Konica?
thank you
  • louise69 Sep 30, 2008
    thanks, Checkitright. I'll look to see what connector it has...
    it doesn't have a network card, and apparently it would be very difficult and expensive to get one.
    The wireless router option sounds interesting, maybe my IT guy understands how to do that.
    louise69
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Not sure if you are saying it has a NIC card or you would like to put one in.
If it does not have one, yes it's expensive and most likely they did not make one for that model.
If it has one
depends on the connections.
IP address is for a network, don't know the setting you are in,but, if there is another connection ( Parallel) this is the big connector that is used in the old machines and computers (before USB) and is connected directly to the PC. so it's considered Local printer and only that person can print, would be an alternative.
Unless you have a wireless router, and put the printer into a shared File
Posted on Sep 30, 2008
  • CheckitRight
    CheckitRight Oct 01, 2008
    Sorry, the wireless is not going to work if you do not have a network card !!! so, unfortunately that model can not print from your PC regardless of what you try.
    Konica DOES have a Nic card for that model however, read this (dated 1998)
    http://findarticles.com/p/articles/mi_m0...
    Try a local Konica service facility, they will or can get the part hopefully the part should cost about 300-400 by now. If the copier is in good shape and your whole office will benefit then it outweighs the cost.
How can I download driver for Konica Minolta bizhub C-252 on windows XP and direct to unit with ethernet cable?
Robert, C-252 Copier prefers that you give it a IP address (Call Static IP) Do not use DHCP which the network determines .
Go Administrator, Admin One Network TCP/IP have your network administrator determine best IP address for your network.to give the copier
Dec 17, 2014 | Konica Minolta bizhub Office Equipment &...
Konica 7033 F-28-2
High Voltage issue have a tech come. Will have to have Old School knowledge you have a legacy Konica Machine.
Jun 12, 2014 | Konica Minolta Copier Toner 7033/7040...
Problem scanning with Konica Minolta bizhub C220
does the copier have a static or dhpc ip address? All copiers love static. ensure one is issued.
Apr 19, 2014 | Konica Minolta Minolta Bizhub 220 Color...
Just installed printer and drivers via a network connection for Vista 32bit. I did this per the instructions Provided by Konica at ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista...
I presume that the IP Address in the instruction is just an example IP Address. I don't know if your printer is connected to a router or to a Hub or Switch, but your printer's IP Address should depend on the device that provides the IP Address and the example is router. The first 3 octet of the Printer should be the same as the router's. So the setup should be router->printer then router->computer.
Feb 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Copier won't print - IP address was switched?
i need a service manual of minolta di251 digital cpier
Dec 11, 2007 | Konica Minolta DiALTA Di200 Copier
427 people viewed this question
jasbo
jasbo
