Question about Solis Maestro Electric Burr Grinder
Replacing hopper after cleaning
I took my grinder apart and brushed all the parts and put it almost back together. I am unable to seat the hopper properly. Seems as if it does not settle deep enough. very shaky
  • Graeme Shepherd Jun 16, 2012
    Yeah, I'm not getting any luck here either. People either offer a solution to putting a hopper in when there is no steric hindrance from something deep inside and the hopper won't actually fit. Or they start talking about mods and how they make superior coffee to everyone else. No useful solutions yet. Mine might be thrown across the road soon.
The hopper has two slots in the bottom that aligns with two black tabs in the base. Rotate the tab ring in the base counterclockwise and then install the hopper.
Posted on Oct 25, 2008
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
I am having problems putting the hopper back in the burr grinder
Sometimes my wife or I pull the hopper out before the grinder is totally stopped and then some coffe gets behind the hopper. Thre are a couple of small slots that hold the coffe and the hopper will not slide back all the way again...we then need to take a knife and clean everything out good before it will work again...
heatman101
May 02, 2010 | Solis Maestro Electric Burr Grinder
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Embarassing but...
No, wait, I found it. If it's round and is (or used to be) white, it fits on the bottom of the clear plastic hopper. Replace it and you should be in good shape again.
Jan 02, 2009 | Solis Maestro Electric Burr Grinder
Osyer burr mill 6389
Apparently, you unplug the unit, dump any beans out of the supply hopper, then rotate the burr intake module in the bottom of the supply hopper counterclockwise. You can then pull it out, and brush it out. You also brush out the other half of the burr unit; don't put water or anything in it, you'll kill your grinder. You can, in theory, wash the removable module, but if you do, be sure it's ABSOLUTELY dry before you put it back together.
Jun 15, 2008 | Oster Coffee Burr Mill - 6389 Grinder
Burr grinder GVX212
I had the same problem, took it all apart, separated the two halves, and looked into the guts of the machine, not an easy task. Fiddled with this and that, and looked at the back of the switch mechanism, and heard it making a 'click' when depressed, so put it all back together, to no avail...It turns out the grinder needs to have two limit switches engaged, one between the lid of the ground coffee hopper and the underside of the grinder hopper housing, and the other between the grinder lid and the base of the unit. This last limit switch was my problem, it seems the lid wasn't making contact with the limit switch, so the unit didn't run. I cleaned out the narrow gap that the grinder lid sits within, pressed the lid down until I heard a small 'click' , pressed the on switch, and presto! it works. You can see this very tiny switch if you take off the grinder lid, and look in the narrow gap it sits in at a position of about three o'clock ( the back of the machine when viewed from the top being 12 o'clock. Hope this helps anyone else who can't find their receipt within the one year warranty period. This is the best burr grinder I've found for the money, and I'm glad mine's still o.k.
May 20, 2008 | Krups Burr Coffee Grinder
Gaggia Trevi or Spidem Trevi
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Jan 02, 2008 | Spidem Trevi Anthracite Espresso Machine
Solis Maestro Electric Burr Grinder Logo
202 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Mike Cairns
Mike Cairns
isaac johny
isaac johny
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
