Question about OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 320 Turbo Printer - forms don't maintain registration
Hi. We have a couple of these printers. They work fine when printing full pages, but when we use forms where the information has to be printed on certain lines of the page, over a period of time the registration will drift down the page. We typically print a hundred forms at a time and by about number 20, the registration is bad enough to require manual adjustment. Any suggestions?
Thanks,
Richard
  • 1 more comment
  • rwalter Nov 07, 2008
    Thanks for your reply!
    Actually the forms are being fed through the bottom using an accessory form tractor feed/stand unit that provides a straight paper path. Previously the forms were heavier stock and required this. Now they are lighter stock but we are still using the tractor feed from the bottom.
    Regards,
    Richard
  • hjohnson435 Nov 24, 2008
    Our printer drops a line with each page and we have to readjust the forms. We too have the bottom form feed. It worked fine for a while and then started messing up. Have you found a solution?
    hugh johnson
    little rock, Arkansas
  • Felix Lopez
    Felix Lopez May 11, 2010
    Are you using perforated forms? If so, have you set the paper feed knob for rear feed? This problem os common when the printer is set to friction feed.
    Be blessed.
    Guru:
  • 1,049 Answers
On older printers, tractor feed edges separate from the page while printing. Sometimes this can be a fluke, but other times it may point to a mechanical problem. Try taking the paper out of the printer and hitting the form feed button a few times. Watch the printer’s tractor feeds to make sure they are moving and are in synch with each other. Some printers use belts to move the tractor feeds and, over time, these belts wear, break, become smooth and slip, or become misaligned.
Environment can also contribute. Paper stored in a warehouse can weaken in intense heat or moisture. Carbon copy paper will especially cause this type of problem as one sheet's feeder edge can break away from the rest and peel slightly back. This will in turn slow the feed on one side as the edge buckles slightly under and may even skip to release pressure causing major alignment problems.
Posted on Mar 22, 2010
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
Microline 320 turbo won't go into menu mode
just use the buttons, SHIFT+SEL(MENU) with the printer on and you will see the MENU light
Sep 05, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320
Looks like you can get the non-T manual from the Oki site:
http://my.okidata.com/PP-ML320.nsf?opendatabase
Aug 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320 turbo 9 pin printer
What driver are you using, you should try the IBM Proprinter Driver.Hope this helps.
Dezzi
Feb 11, 2008 | OKI MICROLINE 320 Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
479 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
