Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer when I copy it comes out blank and there is plenty of ink.
  • vikingfan72 Sep 30, 2008
    what is "transit lock" and how do I unlock it? I copied a paper last week and it worked fine. It does everything else it's supposed to do.
  • 661 Answers
Perhaps you have not unlocked the "Transit Lock" for the scanner head.
can you print and scan ok?
Posted on Sep 30, 2008
  • Gareth Cockram
    Gareth Cockram Oct 01, 2008
    The transit lock stops the scanner head from being destroyed in transit, if you have been able to scan / copy it seems that you have unlocked the scan head.
    it is possible that you are putting the original in upside down..........but that is unlikely
    have you tried scanning to your computer, does that work properly?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 71 Answers
Possibly something to do with the scanner not scanning images propperly or you may have the paper in the scanner wrong ?
4 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: copys come out blank
A couple things can cause this you may not have tried yet.
  1. First in your printer driver properties, select the highest dpi setting and the correct paper setting for your type of printer.
  2. Run a print head cleaning cycle. Run up to five cycles in sequence. Print a nozzle check pattern after every one or two cleaning cycles to see if you have made any progress. On most printers, after approximately every fifth cycle, the printer will perform a more powerful head cleaning routine.
  3. Clean the capping station The capping station is a rectangular flat sponge surrounded by a raised gasket. When the print head is in the “parked position,” at the right side of the printer carriage, the gasket of the cap presses against the print head, sealing it. One purpose of this is to keep the print head from drying out due to air exposure. Instructions: (1) push the “ink change” button to move print head off the cap. Unplug the printer (2) Look inside the printer case, below where the print head was originally sitting, to find the cap or caps. A cap is a rectangular piece, approximately 1” high by 2” wide(3) Look at the cap, using a flashlight if necessary. It should be horizontal, not tilted at an angle. If it tilted, there may be a problem with the fixture supporting it. (4) Clean the cap. Sometimes you may notice a buildup of residue or liquid in the cap or on the gasket; other times you will not. Use a drinking straw to deposit warm water, or use the tube from the inside of a bottle of Windex to deposit Windex, onto the sponge. Use your finger to dispense only two or three drops of liquid at a time. The liquid will remain in the cap for a few seconds, but will soon drain out. Repeat this several times. Try not to let the Windex or water spill around the cap, and into the printer. (5) Fold a paper towel into a 4”x4” (10cm X 10cm) pad. Press the towel gently on the sponge to dab away ink and water or Windex. As you push on the sponge, push down and slightly to the right, to protect the spring-loaded mechanism that supports it. (6) Dip a cotton swab (Q-Tip) in water, and use it to wipe gently around the edge of the capping station gasket, to remove dirt buildup there.
  4. Ink flow problems can occur if the air channels on the top of the cartridge become blocked. Check to make sure the cartridges that their is not bits of machined plastic on the top that was not properly removed.
Posted on Aug 07, 2008
bandana_gyrl
  • 181 Answers
SOURCE: When I put an original on the glass to copy, copies come out blank but cartridge has not run out
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity and therefore it is not taking an accurate picture.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. Do you have the same issue when scanning?
If it happens when you scan and it is plugged into the wall and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
  • 162 Answers
SOURCE: HP 400 Printing a blank page
You could try the following Steps from HP's Homepage :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=au&docname=bud09143&dlc=en&product=58649
Posted on Nov 24, 2008
Printing blank page
Open the top and make sure the carrier is not stuck to one side and also check that the drive belt is on.
Jan 27, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Hi.. I have a Lexmark X6180 printer and it stopped printing. The paper goes through, and it sounds like it's printing but the paper is blank when it comes out of the printer. There's plenty of...
It could be that your cartridge needs cleaning. On your computer, go to Start menu > Programs / All Programs > Lexmark 6100 Series > Lexmark Solution Center. Go to Maintenance tab > select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print your document again and determine if the problem is fixed.
Jun 24, 2011 | Lexmark X6180 Printer
Does everything as if it is printing but the page comes out blank. Plenty of ink in the cartridges
Try to do the Deep Clean Printhead function on the printer. Press Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 01, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My printer has plenty of ink but will not print properly
my lexmark is connected to my pc, my ink is more or less full it is making all the right noises for printing but the paper comes out blank...........please help its a lexmark 1200
Jan 10, 2011 | Lexmark X2670 All-In-One Printer
Same for me
remove cart and soak in rubbing alcohol over night, clean with soft cloth where ink come out of bottom, try not to touch gold contacts on front of cart.
Sep 14, 2009 | Brother MFC 490cw Color Inkjet...
HP Photosmart C4490 won't print
teps on how to change jet ink cartridge where do i pull on the printer.
Jun 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Nov 24, 2008 | HP DeskJet 400 InkJet Printer
Jul 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
My Dell A940 is not printing with black ink.
how long have the cartridges sat? I've noticed after about a week, that dell ink clogs up. Also, Lexmark makes most Dell printers. In my time as a cartridge refiller, we blow through dells and lexmarks and when they **** out, usually it acts like it prints, but nothing comes out printed, only blank pages
Mar 29, 2008 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
