Question about Philips 60P8341 60" Rear Projection Television
Philips Proyection-60P8341 from the PTV915 series
Hi, I'm having problem with this TV, and I hope that you can help me, get out of this dilema, The TV is not powering up, I can hear the voltage, when I press the power button but nothing comes up. and the power button light stays red, I suspect that the voltage is being drained but I have checked all diodes, resistors, and caps of the power supply board, I have disconected the signal board to see if it was the STKs, I have had replaced the HVG (flyback), I have replaced the vertical, and horizontal transistor, and so far, no changes,
I'm basically breaking my head over this, Would you be able to give me any suggestions?
Thanks
  • Philips Master
  • 8,617 Answers
Those models are famous for the LSB boards going bad and they are hard to track down the cause if the LED isnt blinking. You can get a repalcement LSB for your model at the following link. Leave them a email and they may make you a good deal on one. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 30, 2008
Is there anyway to repair the flyback transformer of a philips tv model 60p8341
You are asking to repair the flyback transformer and you can replace that......but you may have more problems than you think. To take this board out is very tedious and time consuming. You will need to use extra care to remove...I cannot tell you enough. If you beleive this board is the problem...I would certainly get a replacement [reworked or refurbished] board. Please check with Union Electronics, phone# 1 800 648 6657. This is a well worth effort, and I would hope you can understand that I'm trying to help you repair this TV the first time. You will not like to remove, replace, remove, replace etc. Hope this will guid e you..and thanks for asking me!
Jun 03, 2010 | Philips 60P8341 60" Rear Projection...
Philips TV keeps kicking off(lose of power)
moses1,
What you have there is a PTV915 chassis that has an Ssb board failing in it... To be more precise the smt (Surface Mount Technology) caps on the Ssb are failing. The board is mounted on the Lsb (Large Signal Board) vertically, just behind the tuner.
The module itself is Philips original p/n# 313912725871 and has been subbed to Philips p/n# PH3912725871 they're about $275.00 dollars.
Or you could take a risk and order one. But I'd still have the technician come out and install it for you... There are some star screws, which Philips has some infinity for, that are kinda difficult to get to and they need to be removed to access the module and extract it...
Hope this helps!
Bill
Nov 10, 2007 | Philips 50P8341 50" Rear Projection...
MY TV DIED=(
Your controller board went out inside the TV and needs repair. I hope this information helps you out.
Apr 23, 2009 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
No sound from a Philips model 60P8341...
Hello Jarvis1,
This is an indication that the actual sound output is working, but the amplifiers to the speakers are not. How you could take care of this is to check in there are any loose connections to the speakers. Then check if you have sound coming from the leads of the output stereo amplifier (You will need the schematic and an audio tracer/tracker to find this location and test for sound). I would venture that there would be no sound from the amplifier. If not you will have to replace the amplifier chip. I would suggest getting a qualified TV technician to perform this task. If you do have sound at the output of the strereo amplifier chip, then it might be a case of the earphone jack switch being broken, let me explain when you plug in your earphone the speakers are disconnected by a switch in the earphone jack if this switch is broken it could disable the speakers and produce these results. There is also the possibility that you have the speaks disabled from the menu of your TV (check this too, actually check this first).
I hope this helps,
Thank you,
Shuttle83
Jul 03, 2008 | Philips 60P8341 60" Rear Projection...
PHILIPS 60P8341 PROJECTION TV NO PIC NO SOUND
Thats the DPTV 300 series phillips HDTV its definatly worth fixing. How are your troubleshooting skills. Sounds like either a problem in the LSB or SSB circuits boards. On our website we have replacment circuit boards for that model. Our prices are less than half what others are getting. Let me know if you would like me to post a link, we also have the service manual for your model.
Mar 08, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60P8342
Iam looking for this part 313501707611 it's that board brook
Dec 19, 2007 | Philips 60P8341 60" Rear Projection...
I have a philips 60p8341 tv
Hi, the fluid in the tube has to be replaced, big & dirty job, set has to go to the shop to do this, be advised that this happens to all Philips rear projection tv`s eventually, problem is (besides being expensive to do) if the green fluid is getting cloudy the blue tube is not far behind. This can be confirmed by removing back bottom cover and looking directly into the lenses, you`ll see they are cloudy compared to the red one that almost never becomes cloudy, sorry to be the bearer of bad news, if you have more questions ask away, BMW Rider
Dec 10, 2007 | Philips 60P8341 60" Rear Projection...
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
259 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
