Question about Philips 60PP9352 60" Rear Projection Television
60PP9352 philip hdtv
My 60 inche TV has a slight wave at the bottom and top left hand side of tv. It also looks like it needs slightly focused. The multipoint blue crosses are very dim. the multipoint red is ok but you can see a wave of the crosses at left hand side top and bottom of screen.
  • 2 more comments
  • wwkMrWhite Oct 01, 2008
    I am having a very similar problem with my TV (same model) except mine is only acting up on the left.
  • holla1 Oct 15, 2008
    The lettering at the bottom of the screen is blurry. How can I fix this. Someone told me you can adjust the guns how?
  • ajlandry76 Nov 26, 2008
    Same problem, wave of color at bottom, like the colors are seperating. Also happening in upper left corner! Help!
  • ajlandry76 Jan 10, 2009
    We just opened our tv up today and fixed it after receiving the repair kit suggested by Ecollier2012. Covergence problem is fixed!!!! Thanks so much!!!!
  • Philips Master
  • 3,459 Answers
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from
Posted on Dec 22, 2008
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
The colors on our tv are slightly misaligned. I'd
hello i would order a remote first if the colours do not relign then it could be the convergance chips may be the problem good luck
Aug 06, 2009 | Philips 60PP9352 60" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
Convergence problem with Philips 60PP9352
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Philips 60 inch rear projection t.v. model number 60PP9363H/17
Oct 26, 2007 | Philips 60PP9352 60" Rear Projection...
Picture problem
Convergence overhaul needed =====
1)Pull chassis
2)Replace Stk392-110 IC's x 2
3)reset alignment
  Usually a 400.00 repair at a tv shop......T.
Oct 18, 2007 | Philips 60PP9202 60" Rear Projection...
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Philips 60PP9352 60" Rear Projection Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
