Question about Linksys Wireless-G WRT54G Router
Wireless g router setup
Unable to get pc to detect router
  • 1 more comment
  • dsmiles Oct 03, 2008
    when i try setting up with the cd, its unable to to detect the router.
  • metrojr2003 Dec 23, 2008
    have linksys wrt54g tried to use setup cd then tried using web everytime neither way will not detect my router i am wondering if router is good how can i check all led's that should be lit are
  • Nico Cunningham May 11, 2010
    Add more detail:
    • Whats happening when you try?
    • What do you think is causing it?
    • What type of router is it?
    • Do you have a wireless router card?
How do i connect to wireless router
Does your TV have wireless built in or does it need a dongle to function? Go into the setup of the TV and see if the network is even being detected. You will likely have to go through the setup menu so that you can apply the access password for your wireless.
Jan 04, 2015 | Vizio Televison & Video
What does it mean when it says unable to scan for networks
Basically it means either -
1. The printer's network configuration has not been setup properly, ie. the wireless router/access point's SSID and encryption settings etc.
2. Your wireless network is not working or weak wireless signal and the printer cannot detect your wireless signal from the wireless router/access point..
Dec 25, 2011 | Office Equipment & Supplies
I have wireless internet but cant get a connection. I put the password in and still tells me unable to connect to the internet and to choose internet settings and then confirm and the same thing keeps...
Have you tried going to control panel, find wireless network setup wizard. Follow steps to setup
for the router you are using.
Also, check internet properties on explorer , connections tab. should use automatatically detect settings.
Feb 10, 2011 | Computers & Internet
Able to detect other wireless networks (eg Neighbor's), but unable to detect my wireless router's signal. My wireless signal, however, is detected by other computers, and therefore is transmitting.
Uninstall The Belkin Router manager Software
This is important to maintain a stable connection
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 22, 2010 | Belkin Basic Wireless Router
Able to detect other wireless networks (eg Neighbor's), but unable to detect wireless router's signal. Wireless signal, however, is detected by other computers, and therefore is transmitting.
Have a Dlink wireless router, however I am unable to set up a wireless connection. ssid=unknown, additionally all other data other than p/n, s/n ip:192.168.0.1, pass=ADMIN. I have a wireless laptop, hp...
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
you should be able to loginto the router and setup the wireless - if you are not able to login - you may need to do a factory reset and then login using the default settings and reset up
a useful tool for detecting wireless networks is this http://www.xirrus.com/library/wifitools.php you can use this on the PC to see if the wireless is broadcasting, if you can detect it on the PC
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
WRT54G, unable to install router
  • Since you have Internet connectivity through the router using a direct connection to the router, then you just need to access the router's setup page and re-configure wireless.
  • But first, check if the wireless light is on in the router.
  • Then, using a computer that is wired to the router, launch IE and type 192.168.1.1 on the address field.
  • It will then ask for the password. By default it is admin. Just click ok and it will lead you to the setup page of the router.
  • Then, on the menu click Wireless. Look for wireless network name or SSID. That is the name of your wireless network. By default it is set to "linksys". You may change it to a uniqune name and then save the settings.
  • Then, if you want to enable security in your Wireless network, click on Wireless Security.
  • Set security mode to WPA Personal and create your network key. It should be atleast 8 characters.
Hope this helps!
Dec 03, 2008 | Computers & Internet
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
128 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
