Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Model ghw9200lw
Keeps getting Suds or F02 error, the pump sounds funny, I have pulled the pump, checked the outlet hose and it was clogged, but not now. It will push water out for a little while then it stops pumping the water out and stays in the bottom of the washer.
  • 5,911 Answers
The errrors are generally related to one another. The "F02" error is a slow drain problem. The "SUD" gets generated because it senses air in your drain pump (due to a possible blockage). More than likely you have an obstruction in your drain pump and you will need to clean it out. This is probably the reason for the pump sounding strange too. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow the link provided and this should be a an easy process for you. Keep in mind, however, that if there has been something obstructing your drain pump for any significant length of time, you may have damaged to pump. It doesn't take much to cause irrrepairable damage (I know, its a crappy design). If you clean out the drain pump reservoir, and the error(s) reappear, you will have to replace the drain pump.
If you require a replacment pump, you can purchase a new one on line at searspartsdirect.com. Just type in your model number and the pump can be located under the "Pump and Motor Parts" heading as item number 10 (part #8181684). For instructions on how to replace the pump, follow this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Hopefully, it won't come to the point of replacing the pump, but you have the information if you need to. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 30, 2008
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello...my Whilpool Duet washer keeps giving a SUD and F02 error. Now...this just happened a couple months ago and we replaced the Drain Pump Assembly...is it possible that we are once again going to have...
Hello, W/D here.
What you are seeing is the suds (SUD) error code, followed by a long drain fault code (F02).
This does not necessarily indicate that you need to change anything at this time. When the machine senses too much suds, the error code is displayed, when too much suds are actually present, a longer drain time results.
Duets are HE (high efficiency) machines, and require a detergent that produces little suds. If you are using HE detergent, cut back on it until you can run a cycle without getting the SUD/F02 alarms. If you are not using HE detergent (we don't either), you really have to be careful with the amount of detergent used.
Press PAUSE/CANCEL twice to clear the display. Run a cycle without any detergent to flush the machine.
It is advisable to check that the drain hose isn't plugged or have a kink in it.
Make sure that the pump is running. You may need to check the electrical connections at the pump.
You might check the filter on the drain pump for debris or foreign objects, which might cause the drain cycle to be extended.
If limiting the detergent, and nothing was found in checking the other items listed, then the pump may need to be replaced.
Best regards, --W/D--
Please help us by rating our solutions. Thanks.
Feb 21, 2011 | Whirlpool GHW9300 Duet Washer
Whirlpool duet flashes F 02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
My Whirlpool washer (model # GHW9200LW, serial #CSM 4604196) is blinking "F02," which means there is a drain problem. My husband disconnected the drain hose and cleaned it. The washer continues to blink...
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error Pump Filter hoses all ok. Whirlpool duet front load.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Making bad ckicking sound and f02 keeps coming up
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f02 keeps coming up
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$#$
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It keeps F2 me or saying suds I can't remember
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Jan 03, 2010 | Whirlpool Washing Machines
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
971 people viewed this question
Dan Webster
Dan Webster
Sal De
