Question about JVC KD-PDR30 CD Player
Zeros on the display
Hi, about two weeks ago I started getting about four or five zeros on my radio display followed by an "A". The radio continued to work and the zeros go away for a few seconds when you hit a preset or load a CD but they come back after a couple of seconds. Now, as of yesterday morning the radio and the CD no longer work.
This radio is less than a year old, purchased at Circuit City in the Woodlands Tx.
Ideas ???
  • K.N. Oct 15, 2008
    I have the same problem. I bought mine from BestBuy last January.
    I called JVC at 1-800-252-5722.
    Their customer service department told me that the radio has to be taken to a JVC service center for repair. They told me that this issue is a microprocessor issue.
    They can give you the local authorized JVC service center. Mine is "JOTS Electronics" in Arlington, Texas
    The good news is that the radio has a two year warranty (if I can just find my receipt.....)
    Good Luck,
    Kent
    Problem Solver:
  • 16 Answers
Where you bought it should have a record of you buying it as well, make sure to bring all thr proof who you are, and try to remember the date you bought it. all the info you can give will help them locate the sales tag.
Posted on Feb 15, 2009
12345 security code is not except in nokia model 1650
*#7328748263373738# to reset security code to default.
Default security code is 12345
i hope this helpful
thank you for using fixya
Mar 07, 2011 | Nokia 1650 Cell Phone
Radio code resetting
There is a four digit code for the radio, the previous owner will know it. Press two bottons at the same time and the display reads "0000". use the first four keys on the radio, that is "1", "2", "3","4" for each of the zeros and enter the code by pressing until the right number is displayed. Then press the same two bottons to enter this code and the radio comes out of safe mode..
Nov 16, 2009 | Audi A4 Cars & Trucks
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
How do i put my radio code into my renault scenic
when you get the four zeros on the display press no1 for what number you wish to display, then repeat for the following three numbers, eg code is 4 5 6 7 so press number 1 four times, number 2 five times, number 3 six times and number 4 seven times, when code is entered press and hold the number 6 button.this will reactivate the radio.
May 06, 2009 | Car Audio & Video
My renault scenic radio says code i am unable to enter the digits for the code
Hi - the way to enable code mode is to turn off the radio - then hold down 2&5 & press the on button - this will bring you into the 0000 code mode.
Regards Paul
Feb 22, 2009 | Renault SCENIC Cars & Trucks
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
JVC KD-PDR30 CD Player Logo
81 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
