Question about Nikon D40x Digital Camera
Blurry flash shots
My flash shots seem to be blurry like the camera needs to be set on a tripod, no matter how steady I hold it(no shutter release punching), therefore the flash is useless. Anybody know how to adjust?
  • Mark Shofner Oct 01, 2008
    I finally figured out how to change to higher shutter speed on S mode, but even though I hit the flash button on the left side of the camera which pops up the flash attachment, it doesn't flash. I haven't found much help on navigating in the Magic Lantern book guide I bought.
  • Mark Shofner Oct 04, 2008
    Thanks for the response from dsiphoto and Steve5. However, the initial reason I went to S was that the P was the initial problem with too slow shutter speed. I just noticed that the flash doesn't work with P now. Probably just need to get a technician to fix it, too late on the warranty.
    President:
  • 423 Answers
Try shooting in "P" mode with the flash manually popped up. You should get a fairly fast shutter speed.
Posted on Oct 03, 2008
Try increasing your shutter speed (maybe 1/250)
Posted on Oct 01, 2008
  • dsiphoto2006 Oct 15, 2008
    If you're shooting in S, your shutter speed is controlled by you.  If you're still getting blurry at 1/250 try increasing to 1/320 or faster speed, or even use a tripod.  I've only had blurry photos due to two reasons: too slow of a shutter speed and human movement (either my end or the subject's end since I shoot people a lot).  Hope you get it figured out.
Our Canon Power shot A95 is used to take close up photos of jewellery ,with a white background.We have been useing the TV mode with the MF to focus.Howerev the pictures are over enposed, what can we do to...
Instead of shutter priority "Tv" mode, try setting to program "P" mode instead. Also, turn off the flash, and set to macro if shooting close-in (press downward on the little flower icon on the back disk). If pictures come out blurry, try using a tripod to hold the camera steady, or set the camera down on an object so it doesn't move while taking the shot. Try using the timer to activate the shutter to allow the camera to remain even steadier for the shot.
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Jan 20, 2010 | Cameras
Blurry indoor photos
blurry pictures often comes from the slightest movement when the pictures is snapped.
Don;t know if that is your problem or not try a photo tripod and see if that helps or check your trouble shooting area of your amnual. if you don't have the manual go to this site for any type of manual::::
http://tv.manualsonline.com/search.html?q=vr+5940&submit.x=35&submit.y=14
Aug 28, 2009 | Cameras
My photographs are blurry
just set the shutter speed yourself. and unless its on a tripod it wont be steady enough.
Jan 19, 2009 | Nikon D50 Digital Camera
Problems taking photos at night.
Did you use flash? Did you use tripod? Generally speaking night photos with non-DSLR digital camera, W55 is non-DSLR, will be blurry unless either flash is used or a tripod is used. The issue is the camera shutter is set for a long exposure in order to get enough light that it is impossible to hold the camera steady. The color problem you mentioned is most likely your white balance. Normal white balance is sunlight at night you white balance should be Auto, Incandescent or Neon
Jul 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Blurry pictures...
There are manual settings for shutter speed and aperture. You may want to us a tripod or a camera stick to steady it. There's also a burst setting, which lets you hold the shutter button, and take shot after shot. It's a good camera- experiment with it.
Jan 26, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Taking night photos with the A350
I suggest you find a tripod and use "No Flash" as the reason the pictures are blurry is usually the camera moved. I love the no flash option, but since the shutter stays open so much longer, a tripod is almost a necessity.
Dec 16, 2007 | Fuji FinePix A350 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Picture Blurry on the Sony DSC-T1
Put it on a tripod, and don't move it until the picture is captured. At the very least, hold it steady for several seconds after you press the shutter button. You are probably moving it while the shutter is still open recording the image. Digitals do this in low light situations. I frequently get caught by this because I think 'Click. I'm done. Move on.'
Sep 08, 2005 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures have come out blurry and out of focus
The most common problems that most new users encounter are: 1. Trying to focus closer than @7 ft. when zooming at greater than 6x. The camera won't do it, and that zoom is tempting. 2. Not waiting for the lens to focus before completing the shutter press. Try holding the shutter at half-press until you see the steady green indicator, then gently press fully to take the shot while holding as steady as you can. 3. Expecting too much from OIS. If you're seeing the "jitter" icon a lot, that means that you're into the range of slower shutter speeds that OIS might not be able to compensate for.You might try switching to a higher ISO speed (or turning on more lights)-- yes there will be more noise, but it'll quicken the shutter speed, and a non-blurry pic that's noiser is better than a clean blurry one. . . and you'll learn a little about what you're camera will do under different conditions. Also, you have to really make the effort to hold the cam steady, even with OIS, especially when using slow shutter speeds.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Nikon D40x Digital Camera Logo
83 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
