that item is called a relay switch. it toggles on and off depending on which electrical component it is connecting. if it's blown, they are cheap and easy to replace like a fuse, but you'll need to look at the fuse box chart (usually on the underside of the lid) to determine which one and where it's located. You can't look inside the relay to determine if blown, but you can replace them one at a time to test...
Also, if you're experienced in electrical, a paper clip can be used when the relay is out, to connect the circuit that you need. use tools and or gloves when attempting this method.
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time. Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
The car will not start, just make clicking noise, it can be problem related to weak car battery or faulty starter,When starter gets faulty, it will just make clicking noise,But if battery looses its charge then also same noise will be heard.So first test car battery.It should have 12 volts.
If it shows 12 volt,then check the starter and its connections.
For more troubleshooting, click the link below:---
http://howtobyme.blogspot.com/2011/10/car-troubleshooting-tips.html
This should help.Thanks.Helpmech.
