Question about HP PSC 2210 All-In-One InkJet Printer
HP 2410 Photosmart All in One Printer
Every time I try to turn off power and then power up, the printer makes this loud constant clicking noise for around 2 minutes. It never prints and once the clicking is done the green light flashes with the hour glass on screen. It seems to be stuck in a function. I have tried turning power off many times and this same thing happens everytime I power back up.
Any suggestions?
Thanks,
Mark
  • mwetzel23 Sep 30, 2008
    Resetting the printer, turning off computer, rebooting computer does not work. When the printer turns on there is a loud clicking noise and it does that for around 2 minutes. Then it just sits there with the hourglass going on the display screen and the ON light flashing.
    Novelist:
  • 169 Answers
I know you're not going to believe this, but here's your fix:
Hold the cancel button down before you turn on the printer on and hold it down through the start up process. This is a know HP 2410 bug, and this fix *does* work.
However, the problem may come back. Just "rinse and repeat" to get it back working again :)
Scott
Posted on Sep 30, 2008
  • HP Master
  • 13,433 Answers
The clicking sound is coming most likely from the printhead carriage, if you open the printer so you can see the cartridges, is the carriage stuck? trying to move to a direction and makeing the sound?
  • 4 more comments
  • Ekse Sep 30, 2008
    Is there a error message on the screen at any point?
  • Ekse Sep 30, 2008
    Perform a partial reset
    A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
    1. Unplug the power cord from the wall outlet.
    2. Unplug the power cord from the all-in-one.
    3. Press and hold # and 3 while plugging in the power cord.
    4. Plug the power cord back into the wall outlet.
    5. Plug the power cord to the back of the all-in-one.
    6. When reset displays, release both buttons.
  • Ekse Sep 30, 2008
    Can you see my solution?
  • Ekse Sep 30, 2008
  • Ekse Sep 30, 2008
  • Ekse Sep 30, 2008
    Have you actually read and tried my solution?
    Genius:
  • 1,913 Answers
Check your cartidge is ok
also try to change the cartidge mose of the problem of ink cartirge.
  • kishor khatri
    kishor khatri Oct 05, 2008
    o ned to change paper sensor detector.
    go to service ssttin and chane.
  • HP Master
  • 1,879 Answers
Turn it off & check for any obstructions inside.
disconnect it from the computer & turn it back on, if it still generates those loud clicking noises which is not normal, the printer may need servicing.
My HP 2410 Photosmart printer is making a clicking nose on start up. In the past I was instructed to unplug it and everything attached to it, including the computer, for 15-30 minutes and it would reset...
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
Apr 06, 2010 | HP Photosmart 2410 All-In-One InkJet...
Loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Why is my hp psc 2410 photosmart all-in-one make a clicking noise, when I turn it on? It seems to be stuck in a "cycle". Like the printing carriage (if that's what you call it) is hooked-up.
See if you can press the power button to turn it off, leave it for 5 minutes then turn it on again, if the clicking persists again try 1 more time, turn off, leave for 5 mins then turn back on this time there should be no clicking noise and you should be able to send a print job to the queue and it should print.
If this doesnt work then goto the hp software and purge.
Oct 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Loud motor sound and green blinking ON light....!!!!
clean the cartridge rails and move the cartridge by hand if possible the full length of the rail, turn off, then on to reset. Hope that fixes it for ya
Jun 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer won't print, makes clicking noise, on/off light flashing
This method should put you on a fresh footing.
1. Go to start button when programs appears see if you can find your printer in the list, see if it has an uninstall program.
2. If not: Go to start click on printers and faxes.
3. Delete the printer giving you a tough time.
4. Reinstall using your installation CD.
That should work.
Victor
Dec 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Hp psc 2410 photosmart all-in-one
scanner replacement is needed as this cannot be repaired,the lower printer part is perfect just the scanner parts needs replacement.it is also costly to get replaced.
Sep 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
2410 Malunction
This problem always hits after a power interruption. On another site I read the solution is to open the back and roll or move the paper wheels back and forth a few times. This worked for me.
Apr 21, 2008 | HP Photosmart 2410 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
358 people viewed this question
Seeker5211
Seeker5211
