Question about Gateway Computers & Internet
I cant get the clock to appear in right hand cornor
  • 326 Answers
Right click on the blue bar at the bottom of your desktop and click properties, theres a tick box in there
Posted on Sep 30, 2008
  • mark hudson Sep 30, 2008
    thank you for rating this :)
Toyota prado 2007 clock reset
I had to just Reset my Clock after the battery was disconnected on my Prado 120 series Grande, firstly turn ignition on and press the 2 outer buttons (of 4) in front of the clock for several seconds, ILLU will appear on the face, with the inner buttons you can turn the brightness/illumination of the clock up to down, then press the left hand button again and by using the inner buttons.....using the left hand inner button to adjust hours and the right hand inner to do minutes, then press the out right button several times to set. (during the last procedure be careful not to reset the Altimeter and the compass)
I hope this helps as this is the only thread on here about this
Jul 26, 2013 | Toyota Land Cruiser Cars & Trucks
How to change time on my watch?
  • Press the top button on the right-hand side of the watch to view time.
  • Press the bottom button on the right-hand side of the watch and hold for two seconds.
    Press the top button on the right-hand side of the watch to choose a 12-hour setting or 24-hour setting. Stop when the desired format appears.
    Press the bottom button to change to time set mode.
    Press the top button until the desired time appears. Press the bottom button to exit time setting mode.
    Mar 04, 2013 | Home
    I have a light on dashboard it is a triangle with what looks like a y upside down in the bottom right hand cornor
    Its called a Lambda light, its the same thing as a check engine light, but for non-US markets, usually from Canada
    Jul 31, 2009 | 2000 Volvo S40
    I have a question concerning the tomtom 910. When plugged into the car, the tomtom goes off and on and the battery is constantly low. However,when I charge it at home, it stays on for about 4 hours. What...
    Connect your TomTom to the car charger and turn it on. Tap the lower right hand cornor where the sat. signal graph is. On the screen that comes up check to see if it is chargeing while connected to the car charger. It should say charging in the upper right hand cornor where it shows the battery status. If it isn't charging then you have either a bad pin on your windsheild mount or your charger is not working. If the charger is not working it may be as simple as replacing the fuse in the charger.
    Jul 19, 2009 | Tomtom GO 910 GPS Receiver
    Can't turn off radio
    See if there is a snooze button. Try that.
    Aternatively, there should be switch on the right hand side, switching it from Auto to OFF, then back to Auto should turn off the morning alarm.
    Failing that, check to see if the switch on the right hand side is set to ON.
    Let us know how you go!
    Jun 22, 2009 | TruTech Clock Radio
    HTC Tilt phone- Digital clock has replaced by clock with hands
    Current time (tap and hold the time
    to change display modes. Here is the User manual: http://www.wireless.att.com/support_static_files/manuals/ATT_Tilt.pdf
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Apr 26, 2009 | HTC Tilt 8900 Smartphone
    Changing oil
    is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
    Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Clock
    you use the FUNCTION key. Press it repeatedly until the clock option appears on the screen and then you can adjust it.
    Jun 16, 2008 | Pioneer Premier DEH-P960MP CD Player
    Complicated GE clock radio/CD player
    To set the time:
    Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
    Use the TRACK Rev Search Fwd Arrows to adjust the time.
    Rev will decrease by minutes and Fwd will increase by minutes.
    Hope this helps.
    Jan 10, 2008 | Audio Players & Recorders
    LCD Dark Hot Spot in lower Left hand cornor
    Well the inveter powers the lamps in the LCD itself. If the lamps come on ,you don't need a new inverter but more than likely just a new LCD! hope this was helpful regards, babb
    May 10, 2007 | Dell Latitude C640 Notebook
    Computers & Internet Logo
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
