Question about Drills
Bosch Jack Hammer
I have a bosch jack hammer and i need to know if it is three phase , i emailed the UK and they told me to contack Bosh Technical for specs on #0844
7360107 But my number is 0612307002 it is 230v 180hz 9A 3000w. the tag does not have anything else on it , thank you Laura
  • Bartos Istvan
    Bartos Istvan Jun 20, 2015
    Hello. i have the same jackhammer. did you find something or someway to make it work? thanks
I am an electrician, 230V means it is single phase. It would be 415V if it was 3 phase. It will have a 3 pin plug, if the centre pin is bigger than the top two it will require a 15amp powerpoint to power it. 3000W / 230V means it may draw 13 amps even though it has 9A on the tag. I would expect it to require a 15amp powerpoint.
Posted on Sep 30, 2011
    Problem Solver:
  • 6 Answers
A plug, on your power cord, with two prongs and a ground is single phase, three prongs and a ground would indicate three phase. Unless I misunderstood your question, that is your answer.
Posted on May 26, 2010
    President:
  • 1,388 Answers
I worked at a tool rental center while I was going to college and learned a great deal about equipment and power requirements for tools. Large electric hammers draw a great deal of amps thus created a problem on construction sites. Bosch and other brands made hammers such as yours that would would work on long extension cords that worked off of special generators such as this one: http://www.southern-tool.com/store/multiquip_gdp-5000h_generator.html . This miltiquip generator has a special outlet for three phase at 230v. Your hammer was probably designed to work on a generator such as this. Hope this helps, enjoy.
Posted on Dec 11, 2008
Need to register my technik TV on line very difficult is there a phone number to ring umc UK ltd
this is all i could find....
Technical Support and Helpline
UK Helpline 0871 2000 463 Our helpline opening hours are:
Monday - Friday 8.30am until 6pm
Saturday 9am until 5pm
Bank Holidays 10am until 5pm
Calls to the helpline are usually charged at a maximum rate of 10p per minute from a landline depending on your provider and your tariff. Some providers may include calls to non geographical numbers such as 0844, 0845, 0870 & 0871 within any inclusive minutes/allowance. Calls from mobiles may be much higher.
If you need to email us regarding Technical support, please first check our Frequently asked questions section by clicking here.
If you have already checked the frequently asked questions section, please complete the online contact form here....
Contacts UMC UK
Dec 10, 2016 | Televison & Video
How to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222 evs
Push the red button all the way in as far as it goes and turn the knob to the left (counter clockwise) past it's normal position. Then you can pull the knob out. When you replace it make sure that the pin part fits inside the slot of the shifting arm inside the tool.
Aug 07, 2012 | Bosch Drills
I have a Bosh 11232 EVS Hammer Drill, but I have no instructions for servicing it. Can you help?
All the manuals for the Bosch Tools can be found a Boschtool.com Just search for your model and it should be there.
Nov 16, 2010 | Bosch Drills
Bosh Brute jack hammer It does not hold chisel bits when locked in.
I have a rockworth arpd 1700 breaker and need new points and chisels any idea where i can get them from ive looked every where.
Oct 17, 2010 | Bosch 11304K Brute Breaker Hammer
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Need a replacement handle for the bosh bulldog extreme
http://www.ereplacementparts.com/bosch-parts-c-128.html
Dec 28, 2009 | Bosch SDS-plus BULLDOG Xtreme Rotary...
I am looking for brush set for Bosh Demolition Hammer 11318EVS. Coul someone tell me where can I get them , please.
Bosch tools has 5 service centers throughout the country, you can search them online at the Bosch tools website. Or purchase them from a tool parts website.
Apr 18, 2009 | Bosch Hammering
Need specifications
hi Laura
see the signs around the operating mode button.Drilling,drilling and hammering,just hammering.Try it and see what happens.
regards savumihai71
Sep 30, 2008 | Drills
I have a EUROLEC RF006 fridge and I need a couple od spare parts can you help please
Premium Appliance Brands Limited
Cranage House
730 Mandarin Court
Centre Park
Warrington WA1 1GG
Tel: 01925 248980
Fax: 01925 244752
email:info@pabl.co.uk Regd. in England No. 04336523
VAT No. 803 2198 55
WEEE Producers Registration Number: WEE/FC0057TS
Customer Support Opening hours:
Monday to Thursday 9.00am to 5.00pm
Friday 9.00am to 4.30pm For general and technical enquiries or to book a service call for your built-in appliance
Tel: 0844 800 7845. Or by email info@pabl.co.uk
Aug 16, 2008 | Refrigerators
Drills Logo
941 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
