Question about HP Compaq Presario V6000T Notebook
Enlarged icons and text
My icons and everything is now enlarged, how do I fix this. I have a Toshiba laptop with windows xp. everything my computer is showing me has been enlarged. i cant seem to get it back to normall.
  • benno80 Sep 30, 2008
    thanx heaps, its done the trick :)
    Sergeant:
  • 268 Answers
The following should get you back to normal:
  1. Click the "Start" button
  2. Click "Control Panel"
  3. Click "Display"
  4. Click the "Settings" tab on the top
  5. Near the bottom is a box that says "Screen Resolution" , to make the stuff on the screen smaller , slide the bar toward the right and hit apply. You may need to slide it over a couple of times to make the display look correct on your screen.
That should fix you right up!
Posted on Sep 30, 2008
Picture enlarged
PC or laptop? Sometimes I find on my PC if I just shut off the moniter and turn it on again, it reverts to normal. Something in the conection, I think.
Mar 18, 2013 | Microsoft Windows XP Professional
My screen of computer is so big the contents are enlarged my kid has pressed some buttons pls help
Hi nayyarshelly,
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
  • First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
  • On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
  • If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
  • But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
  • Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
  • The resolution on your screen depends on how big the LCD screen is
  • On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
I want to know how to change my text size because the words are o big
Go to your control panel in the start menu. Search "Display" in the search box and then click Display when it appears. Then choose to expand things by 125% or 150% with "medium" or "large" respectively.
Mar 13, 2011 | Computers & Internet
Enlarged print on screen - so large cannot read anything ....
I am taking for granted that you are running Windows 7 in that case here are the steps:
Start Panel (Orb in bottom left corner) Control Panel Appearance and Personalization Display.......You should see an option for making the text smaller or bigger click on their (By default it should be set to 100% with the word smaller next to it. This should fix your problem, if not just let me know and we will get it taken care of
Apr 03, 2010 | Acer Aspire One Netbook 8.9" Notebook
My icons and text have enlarged and are now too big for the screen
"Hi, right click on the Desktop screen, when the window open click on (View Icons) "Medium or Small."
Feb 02, 2010 | HP Pavilion dv2000t Notebook
Everything on my toshiba computer is enlarged how do i fix it?
Adjust your display resolution settings Go to Control Panel Click on Display or Appearance Click on Settings Tab Adjust the resolution to the highest level.
Dec 05, 2009 | Toshiba Satellite P105-S6207 Laptop
Iphone icon enlarged
My wife just had this same problem. The entire screen gets zoomed in to where the icons are large. I found that it is a 3-finger double tap function that causes this.
Try double tapping your screen with 3 fingers simultaneously and see if this fixes your problem.
Aug 10, 2009 | Apple iPhone Smartphone
Monitor is enlarged, wont return to normal size
You may have hit the "F11" key which takes the open window to fullscreen. "F11" toggles large, small... If not that, beboot. If that doesn't clear it up, then the display settings have gotten altered. Right click on the desktop, select "settings" and increase the resolution. Windows should prompt you to keep or reject the change. Select yes or no when prompted.
Jan 24, 2009 | Computers & Internet
Wallpaper and icons/text is diplayed enlarged.
right click on Desktop then click properties. across top you will see several tabs. click on Setting. on lower left side you will see screen resolution. move the bar to the left and click ok on size you prefer. you can move this bar until you get the size you want 800X600 or 1024 x 760 would be the first ones to start with
Nov 04, 2007 | Fujitsu Siemens AMILO D-7830 Notebook
Sounds like the display resolution has been lowered, just go in your control panel > Display > Settings, and set it at a higher setting.
Alex
Nov 02, 2007 | Toshiba Satellite P105-S6207 Laptop
HP Compaq Presario V6000T Notebook Logo
264 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
