Television needs power supply module. NEED SUPPLIER OR REPAIR TECH
  • 1,879 Answers
Make & Model ?
Posted on Sep 30, 2008
  • 4,234 Answers
I'd like to help, but a little more info is needed.
1) What is the make and model of the set?
2) What is the problem that makes you think you need an entire power supply?
3) can you describ the problem in detail including any blinking indicators that occur when you see the problem?
Thanks,
Dan
No power do not have any power to the console
It appears that your power supply module has failed and will need to be replaced. You must find a PS3 repair tech who has a power module that you need. Note* They are not all the same. MikesPS3repair(dot)com
Sep 23, 2011 | Sony Playstation 3 (PS3) Console
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
My laptop has a problem of not start once i switched on the on button
Hello Sir, Hi, if your laptop fails on power on, here are possible culprit.
  • definitely there is a power supply problem, these power supply modules are not really serviceable, you need to find a replacement, but if you cant find one, bring the power supply module to a reputable electronics service center, a TV tech. shop will do.
  • there is a possibility of battery problems, but you should see some LED lights on your laptop, to confirm battery is bad, have it replaced, or swap out a new battery,
  • there is a slim chance its the power switch, usually they don't response, if this is the case, replacement is needed, but this goes with the motherboard.
  • if everything else does not solve the problem, its the motherboard. if this is the case, there is not much more else to do, but replace the whole laptop, and but a new one, your dealer may help to contact the supplier if buy any chance may repair the laptop.
Jul 27, 2010 | Computers & Internet
Timer flashes, then lamp light comes on. Unit will not turn on. Lamp not blown.
DM module is not booting up because there are some capacitors in its power supply that are defective in your tv .There are four capacitors that go bad inside your tv in DM module . You need to replace those 4 capacitors . It will cost you around $40 . If you're not a tech, and you'll most likely need to call technician to repair your tv . Hope this helps .
Jan 23, 2010 | Mitsubishi WD-52531 Television
About how much should I expect to pay to have the power supply board replaced by a tech. or repair shop. Again, the TV is a Samsung LN-T4053H.
The power supply module can be from $179 plus tax and shipping from
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1040332-SAMSUNG&Click=35
The labor can be up to 2 hours. Do you have pictures of the bad power supply and the symptom?
Please post back what you find.
Nov 13, 2009 | Samsung LN-T4053H 40 in. LCD Television
STANDBY CONT FLASHES
If your unit is a Mitsubishi then the below information should result in the repair of your unit.
If your unit is not a Mitsubishi then we need to know the make and model of your unit to further help.
Your particular bigscreen has a digital module located on the left rear of the unit, and is mounted vertically. This module can be removed and the shielding taken off. On the component side of the DM module is a small power supply circuit board which needs to have all five electrolytic filters replaced. The filters are typically 1000 micro farad at 25 volts and are easily obtained by you local electronics supplier or repair shop.
The reason your unit does not stop blinking is due to these out of tolerance electrolytic filters. They became out of tolerance when the unit was left unplugged. Once the filters are replaced, and the module re-installed, the green blinking light will extinguish after about one minute, at which point the unit will turn on.
Apr 29, 2009 | Televison & Video
Hitachi LCD Television
it appears that your power supply module is malfunctioning this seems to be a common problem. you need to replace it have a local tech replace it for you
Sep 01, 2008 | Televison & Video
Need power supply
as service rech has iold you that power supply is defective so it is not necessary to replace whole power supply. you can ask him which part is defective that can be replaced easily. as reputed company like SONY design is excellant.lot of protective ckts are there.parts are easily available.please request your tech. to replace part which is at fault.
Sep 18, 2007 | Sony KP-53HS10 TV
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
