Braun shaver swtch will not shut off - Computers & Internet
  • 1,879 Answers
Get a set of tools and remove the case to access the switch in order for you to see physically if there is something stuck or it needs replacement. Post a picture so that we can all see it.
Posted on Sep 30, 2008
    Genius:
  • 3,422 Answers
HI,
I suggest you to manually remove the battery from your shaver and then replace it back after 30min.This will solve the issue.
Let me know if you need anymore help.
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
When I put my Braun series 7 in the cleaning station everything is good. It pumps liquid up to clean then it starts to pulse and the vibration shuts the system down. I redo it with the same result.
I wonder if you can charge the shaver with the cord. Or is the battery dead?
Please also check if the blades of the shaving head are pressed on correct. It is the cleaning system, what pumps up the fluid, and after a while is the the shaver that should start pulsing. So it must be an error with the shaver. If the shaver works normal but does not when not in the cleaning station, also check the contacts on the shaver and on the cleaning station.
Jan 10, 2015 | System Clean 6 Braun Syncro Shaver & Renew...
Where do I oil my Braun 4700 series shaver ? On the foil, the cutting block or where the cutting block plugs into the base area? Thank you.
With the shaver fully assembled, apply one drop to each of the two foils. Turn the shaver on and run for 5 seconds to spread the oil accross the foils
Braun shaver oil can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-accessories/braun-shaver-oil-p-465.html
Jul 20, 2011 | Braun Health & Beauty
I have a braun 7680. after I was done shaving it would not shut off, It was stuck in the on position and would not slide back to the off position. what is need for repairs.
......it is too messy to full around with switch repair as too many plastic parts etc.
ordered the following from Shaveroutlet for $25 and replace the top assembly....takes less then 10minutes.
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
Jan 13, 2011 | Braun Syncro 7526 Electric Shaver
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
http://shaveroutlet.com/shavers/foil-shavers/braun-series-3-370-men-s-shaver.html
http://shaveroutlet.com/shavers/foil-shavers/braun-1775-series-1-shaver-p-123.html
Sep 07, 2010 | Braun 360° Complete 8985 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Trimmer on Braun Pulsonic shaver won't stay shut?
The trimmer is broken. This is a common problem with this model and only an authorized Braun repair center can help you with this. There is one in Evanston, IL that can accept shavers from all over the US. Their phone number is 847-869-7755
Aug 19, 2010 | Braun Pulsonic Rechargeable Cordless Men's...
How to apply appliance oil on braun shaver model 6550
First, make sure that it is shaver oil. Or Braun appliance oil. Other oils may be too heavy and gum up the shaver. Apply one drop ro each side of the shaver foil periodically. If you need Braun shaver oil. it can be found at shaveroutlet.com
Dec 31, 2009 | Braun Health & Beauty
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
