Question about GPS
1998 Twist and Shout Multiplication game modes
I have a Leap Frog Twist and Shout Multiplication which is marked copyright in 1998. I cannot change the game mode from Lightning rod to ? game to the game marked !. I got this used and it had not instructions. Thank you
  • donkyflip Nov 05, 2008
    I have a 2001 model that has similar problem. The game selection dial and the first number selection dial both work fine. The numbers on the second dial does not map to the number the game thinks is selected. Here's my correspondence mapping, first number is the dial - second is number game thinks it is:
    0 = 0 sometimes, other times nothing
    1 = 1
    2 = 2
    3 = 3
    4 = 8
    5 = 9
    6 = 6, sometimes 8
    7 = 9
    8 = 8
    9 = 9
    10 = 10
    11 = 11
    12 = 1
    (lightning) = usually nothing
    (clock) = 1
    Fresh, never used, batteries were put in the game during testing.
2 Suggested Answers
SOURCE: change batteries on 1998 Leap Frog Twist & Shout
After reading the suggestions above, I used 2 screwdrivers to push the white buttons inward while holding the unit between my knees and with unit inverted, pulled upwards until I felt it move. Then I was able to pull the rest of the end off and replace the batteries. Like a previous poster indicated, I removed the other end and 2 pieces fell out. Unfortunately the 2 pieces that fell out I didn't see where they came from. So now the batteries were changed, but the unit doesn't work until I can figure out where these 2 pieces go. Horrible construction design and definitely needs a redesign. It would have also helped if the instruction manual indicated how to change the batteries.
Posted on Nov 09, 2008
I had a similar problem but with the model that only has 1 button. I fought with it sticking a screwdriver in the button and it wasn't coming off. Then I used a pencil and pushed the button down even farther and the whole top including rim came of as it was designed. It looks like they went through several designs before finally putting the battery compartment out in the open
Posted on Sep 17, 2009
What does a Nuvii 55 LM screen green icon with lightning bolt mean ?
The lightning bolt indicates that the battery is being charged. Remove the unit from the charger and the lightning bolt will go away.
Feb 07, 2016 | Garmin nuvi 55LM 5" GPS with Lifetime Map...
How to put in coordinates
Coordinates can be entered by marking the waypoint and editing it.
From the map screen, press the joystick down for 2 seconds to mark the waypoint. Toggle up to the coordinates and press the joystick to enter the edit mode. Make the changes to the coordinates to the new coordinates and toggle to OK, press the joystick to enter the coordinates.
Dec 10, 2011 | Garmin eTrex Venture Cx 2.1 in. Handheld...
Garmin 660 touchscreen not working. lightning bolt on battery icon
Hi Jim,
you need a digitizer, very common problem for the 660...if you want on, let me know...as for the lightning bolt, that means its charging.
Juggerbot
Oct 10, 2011 | Garmin Nuvi 660 GPS Receiver
How do i change a battery in a garmin 305
Hi David!
From your Owners Manual (Page 54)
http://www8.garmin.com/manuals/984_OwnersManual.pdf
REPLACE THE HEART RATE MONITOR BATTERY
"The heart rate monitor contains a user replaceable CR 2032 battery...
Locate the circular battery cover on the back of the heart rate monitor. Use a coin to twist the cover counter-clockwise until it is loose enough to remove. Remove the cover and replace the battery. Be careful not to lose or damage the o-ring gasket on the cover. Then use a coin to twist the cover back into place."
Hope this helps.
Jan 16, 2011 | Garmin Forerunner 305 GPS Receiver
The screen is freezing, and then the battery indicator has a lightning bolt looking thing through it. bad battery? reset?
The lightning bolt means the battery is being charged. Remove the charger and you will see that go away. As far as freezing, you might have a bad touchscreen. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Sep 01, 2010 | Garmin Nuvi 660 GPS Receiver
My Nuvi 200W stuck in boot process
This most likely means that a part of the software on your gps system is corrupted and unreadable. You will need to update it/re-install the software on it. To do that, you can download this software which will automatically search for the latest updates: http://www.tomtom.com/services/service.php?id=16&tab=87
Oct 31, 2009 | Garmin nuvi 200W GPS Receiver
I just downloaded new maps on my tom tom 720 and now it is in Guam and different language. Help me solve it.
it cant be more simple lool.
Just go to change language, and all so to manage maps,switch map, hope this works.
Jan 08, 2009 | Tomtom GO 720 GPS Receiver
Nuvi 350 does not hold a battery charge.I see no way to change battery and the owner manual does not say how.
How old is the unit? Does it show that its charging with a lightning bolt over the battery indicator? Don't try to charge it via the USB port. Try the car adapter or AC wall charger.
Email me at ks3r at sharc dot net and I can replace the battery for you.
- Jim
Aug 21, 2008 | GPS
Change batteries on 1998 Leap Frog Twist & Shout
Aug 27, 2007 | GPS
GPS Logo
105 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
