RCA P60752EBLG1 Convergence Problem
I have a RCA P60752EBLG1 rear projection tv and on the sides and
top and bottom the screen bows like a arch and you can't see the
very end of the picture on both left and right, basically the picture
runs over and can't see a little bit of it. Also there is alot of blue.
when you look at words the blue extends beyond the words like
a blotch. I turned the blue driver down and focused it and is a
little better. Picture is fine to watck just want to fix the arches
onall 4 sides. Someone please point me in right direction. Thanks
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Convergence adjustment to projection TVs are given.
Posted on Apr 24, 2017
5 Suggested Answers
  • 3 Answers
SOURCE: color distortion and arched picture
you have a bad or maybe 2 bad stk392-560 ic's..
and or a bad pico fuse on your g board.. (there are two of them and 6 of them under your ic's
You can check with a vom meter. (resistors) Not ic's need special meter for that
Posted on Nov 05, 2008
SOURCE: Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Posted on Jun 19, 2009
SD Tech
  • 14553 Answers
SOURCE: philip tv has problems
If model number is 55pw9363 it sounds like you have a common problem in these sets--convergence.
If you go into the customer menu and select convergence and it is skewed and will not adjust the set needs the convergence circuit repaired.
I am attaching a couple of photos of sets with convergence trouble for you.
I also have Step by Step start to finish instructions for this repair in this model set--they tell you everything you will need and how to do it..If you are unable to do the repair---most shops are going to get 300 or more for this repair---you can buy almost all the parts you will need on EBAY for less than 30 dollars.
I have repaired hundreds of sets with convergence problems.
If the photos and the information helped you rate this solution as I do this here for free. If you want the instructions let me know and I can post them here for free.
Posted on Dec 09, 2009
  • 1476 Answers
SOURCE: I have an rca hd52w59
Bad convergence circuit. See my tip at for repair help.
Thanks for using FixYa and for the great rating.
Posted on Jul 01, 2011
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Projector out of alignment
Ur convergence is dead,buy convergence kit use what inside that kit,U know how to solder right?Tries website Tv Repair
Sep 28, 2009 | RCA P61960 61" Rear Projection Television
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix using this link on Fixya
Jul 13, 2009 | Samsung PCL5415R TV
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Projection RCA P52940
sounds like it is most likely the convergence power supply board, if it were just one color It would most likely be the convergence board itself
May 27, 2008 | RCA P52940 52" Rear Projection Television
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with convergence
bad convergence ic's
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
