Question about Olympus Camedia D-370 Digital Camera
Camera is inoperable
Camera is unusable - when I try to use it, all it does it beep a bit, green lamp flashes for about 5 seconds, and then it is completely unusable - pressing any buttons does nothing.
  • 2 more comments
  • sonofagun231 Sep 30, 2008
    Camera is Olympus Model D-370
    Never mind - removed batteries for a couple hours - problem fixed!
  • Anonymous Mar 10, 2009
    Did this work?
  • Anonymous Apr 05, 2009
    Mine is unoperable also but I've been trying new batteries for over a year
Remove batteries for a couple hours or more and camera will reset itself.
Posted on Oct 01, 2008
I'll push the power button and the little green light flashes it beeps and the lense comes out just a tiny bit but then in stops goes back in and beeps twice and it's still off. Is there and...
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
Feb 09, 2011 | Casio EXILIM 10.1-Megapixel Digital Camera...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Will not take a photo
there appears to be a power issue and if you have replaced the batteries then you will need to send to repair
Dec 15, 2008 | Olympus Camedia D-580 / C-460 Digital...
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Timer?
There is a small round pushbutton on the top of the camera marked with a clock icon. Pressing this button engages self-timer mode. When the camera is in this mode pressing the shutter release starts a 10 second countdown. The camera will beep during the countdown if the beeper is enabled and the top-deck LCD displays the number of seconds left. Two seconds before the shot the camera will beep faster and the red-eye reduction lamp on the front of the camera will flash to warn you that the photo is about to be taken. You can cancel the timer at any point by switching the camera to another mode (or turning it off) before the picture is shot.
Apr 07, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Olympus Camedia D-370 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
