Question about Garmin GPS
When trying to recharge the battery, the GPS (nivi 260w) believes it's pluged into a computer.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Is this a Garmin charger? Some aftermarket chargers have different wiring on the plug.
    - Jim
Replaced the defective charger.
Posted on Oct 01, 2008
My nuvi 260W displays the computer plug in sybole then turns of both while move and sitting still an d is connected to power supply. I have bought new connector for power supply.
Whenever you see the computer to GPS symbol pop up while using the DC car charger, this is an indication of a loose USB jack (bad connection) between the jack and the printed circuit board.
You should only see this symbol when connected to the PC using the USB cable. You should never see it when using the charger. Please see this link for more information and how to have it repaired:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 09, 2014 | Garmin nuvi 260W GPS Receiver
Garman shows screen of being hooked to a computer but is hooked to car charger and will not load maps
the plug at the back of the GPS is shorted, it will need to be replaced, the part is not avail to the consumer and so you must have it repaired at a Garmin factory approved service center
Oct 28, 2010 | Garmin nuvi 260W GPS Receiver
Hello, My Garmin 260 ran out of battery 3 months ago. I did not attempt to recharge it until two weeks ago. i used a usb cable and plugged it into my computer overnight. It still did not charge... what...
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+260&Show=ExtInfo&gclid=CLzv0pac46ECFQQTawodklsxIg.
This place has the battery and tools come with it!. its super easy and way cheaper than buying a new garmin. 2 screws and unplug the old battery and plug in the new. I did mine and I never messed with the internals before.
May 03, 2010 | Garmin nuvi 260W GPS Receiver
Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
well if the plug is not making contact it cant recharge. you need to have it repaired and that may well be costly as it will require a new motherboard. Parts are no longer soldered or repaired The motherboard will be repalaced and the basic board is ^$90 the labour 1.5 hrs o 2 hrs minimum at $95 I am sure you will be able to buy a new model for the same cost
Aug 01, 2009 | Garmin nuvi 200W GPS Receiver
Why does it take so long to get satellite recxeption?
This can be caused by a low battery, try recharging the battery to full capacity preferably using an AC charger. You might even consider replkacing the battery if its over 2 years old
4 stalleites are needed to obtain triangulation and the unit needs a clear view of the sky. Some heavily tinted windows slow up access so put it closer to the windscreen if possible
Jul 26, 2009 | Garmin nuvi 260W GPS Receiver
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
May 31, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
It can only be used when it is not charging...there are 2 problems with this. 1.If it is not already charged by the time I need it, I cannot use it. 2. If I am driving for a long distance and the batt
Same thing happened with me. But got the workaround......as you are connected the other end to the car battery charger, remove it after starting the vehicle and observe that GPS would act like it is starting. As soon as gps shows "loading maps" insert the power end that you removed from the car charger socket and gpw would continue with the car power.
I hope this help.
--Sandeep.
May 20, 2009 | Garmin nuvi 260W GPS Receiver
GPS Logo
66 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
