Question about Canon Office Equipment & Supplies
I am getting a message in the lcd screen that reads "recommend new c-crt". what does this refer to?
  • 1216bandit Sep 30, 2008
    Thanx very much for the reply....I searched in the manual but didnt see anything! We have not done very much color printing and that is the last thing I would have suspected, but I guess with all the colors in one cartridge it would empty quicker than 3 seperate!
  • 1216bandit Oct 02, 2008
    I filled the color ink on the unit which is a canon mx310 and the message "recommend new c-crt" still appears. Is there a way to re set it?
  • 1,661 Answers
It means 'recommend new color cartridge'. And since all Canon printers do not have LCD screens, you might receive more meaningful help if you were to identify your model when submitting questions.
Posted on Sep 30, 2008
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Hello my printer model in an HP Photosmart 3210 All in one, it was working okay until I replaced one of the empty ink cartridges and now I just receive this message, "Ink System Failure, Ink system...
Greetings sometimes when this happens is that the printer cartridge is not accepting that as the correct model I recommend you go where you bought it and ask for another because this is not working, I recommend getting one new one that is not Refil
Dec 29, 2010 | Office Equipment & Supplies
Read out says recommend new C-CRT. What is
Your printer is recommending you replace the color cartridge.
Dec 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Recommend new C-CRT" appears on the LCD i can't find in the guide
C-crt, refers to the cyan ink cartridge. It's telling you it's almost out of cyan ink...
Jul 16, 2009 | Canon PIXMA MX310 All-In-One Printer
"Recommend new C-CRT" appears on the LCD
C-CRT means to replace color ink cart. because it is low on ink or is out.
B-CRT means the same thing, but regards to the black ink cart.
Press menu button, then go to fax settings, then go to memory reference. Then go to memory list, and hit OK...this will give you a list of everything stored in memory. Then to print each document in the memory, go to print document in the memory reference submenu. Then enter the TX/RX No listed on the memory list.
if that doesnt help.... contact canon at the earliest.....
thank you for using fixya...
have a nice day
Problem with faxing
Goi to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
put "recommend a new c-crt" in the question box. Select the ERROR LCD: RECOMMEND NEW C-CRT answer and follow the instructions to clear the cyan cartridge error. This should take care of the problem. Let me know if this doesn't work. Thanks.
May 08, 2009 | Canon PIXMA MX310 All-In-One Printer
I have the canon mx310. cannot print out what is in the memory. it reads new B-CRT AND C-CRT
the message - recommend new: C-CRT means it needs a new colour toner cartridge and recommend new: B-CRT means it needs a new Black Cartridge.
Oct 01, 2008 | Office Equipment & Supplies
Received in Memory issue
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel.
Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the
"right" arrow key once so that you get "Memory Reference" to appear on the screen.
Press the "OK" button once. It will display "Print List", but you want to "Print Document",
so press the "right" arrow key until you get to "Print Document" and press "OK."
Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document,
choose NO and press "OK" Your document will print out!!! =)
Feb 10, 2008 | Canon PIXMA MX310 All-In-One Printer
77 people viewed this question
old marine
old marine
