My sansa e250 starts but at the "sandisk screen" it gets stuck and restarts
After pressing the play button several times while playing a song the player shutdown and started to "RESTART" in a loop , on its own and i couldn't stop it untill i put the HOLD button on so it stopped restarting but it does that again if i turn it back on , i tried to remove then reinsert the battery but it didn't solve the problem. PLEASE HELP ME !
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Connect it to your PC and open your player in a Windows Explorer window. Some versions of the firmware on the e250 are missing the delete option.
If your firmware HAS the option, while playing a song press the submenu/down arrow button at the bottom. Delete will be one of the options on your screen. This is described in the manual but they don't mention the option isn't there in some firmware versions.
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
try to format your mp3 using the cd included in the package if there is any... if none, google for the software of your pc and format it using the software...
Every time I go to a MP3 on my "MP3 Player" it freezes
the tip about holding the power botton for like 15 seconds works but I still cant get it to play MP3 without freezing
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked!
M.P.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
same thing
except it wont play a song
