Question about Nikon D70s Digital Camera
D70s problem recently i came across a prob with my d70 s digital,its program mode s stopd giving me right exposure but its fine when i shoot in auto mode ,,pls help bharatmaharajkijai ho
  • 4 Answers
Check the exposure compensation setting to ensure it's set for +/-0. To do this, set the camera for Program mode. Locate the exposure compensation mode button - it's the button with a +/- on it immediately behind the on/off switch. With the camera on, hold down this button. If it shows anything other than "0", use the main command dial (the wheel on the back) to change to setting to 0.
The reason the camera works in the Auto mode is because the exposure compensation settings are not available in auto mode, but are available in Program (P), Aperature (A) and Shutter (S) modes.
Posted on Oct 17, 2008
How to work self-timer on nikon d70?
Press the shooting mode button (overlapping rectangles) and rotate the main command dial until the self-timer icon (one-handed clock) is showing.
Nov 09, 2010 | Nikon D70s Digital Camera
I have a Nikon D70 (with a 18-55mm lens) and have always used it in Auto mode. It suddenly stopped working in auto mode...won't take the picture at all. Did I break the lens??? If I tip the camera back...
Hi tina549, do any of your other lens auto focus? If so then it may be this lens. If they do not then look on the right side of the lens mount (with camera facing you) there is the AF and M switch. Something to try is clean the electrical contacts on both the D70 and the lens. When I had a D70s the auto focus was giving me fits, worked sometimes then it did not so I traded it for the D80. The 18-55 lens is a nice lens however, it is not the most robust of lens.
Jun 11, 2010 | Nikon D80 Digital Camera with 18-135mm...
How do I turn the flash on on my Nikon D70?
if u select mannual mode u have to press flash button,whitch is on left side below flash unit,if u select auto mode, flash itself elect when u half press the click button.
Mar 08, 2010 | Nikon D70s Digital Camera
View - Finder reads "OFF"
Firmware problem. That's why the D70s and D70 are discontinued.
Mar 08, 2009 | Nikon D70s Digital Camera
Cant get remote to work on my nikon d70 camera
did you try you shooting mode button and then rotate your command dial until the remote shows up on you screen.works for me!
Jan 13, 2009 | Nikon D70s Digital Camera
In auto focus mode the lese seems to "hunt" and won't focus
When this happens with my D70s, I know of two options. 1) use manual focus or 2) autofocus on another object about the same distance away from my subject (holding the shutter release half way) and then move the camera back to my subject composition. This seems to happen when there is little contrast in the scene, i.e., a field of same colored flowers. Hope this helps.
Dec 29, 2008 | Nikon D70s Digital Camera
Blurry pictures
Both of these problems are caused by underexposure. There are several causes for this. If you are set in AUTO MODE check the shutter speed and lens opening in the view finder. If the speed is less than 100 and the shutter is less than 5 and you are not using flash. You will probably get blured and dark pictures.  Practice shooting with your settings outside in sunlight , inside with lamplight, inside with flash and all of the above with motion. Check the exposure after each shot and make adjustments. In a short time you will get very good at setting your camera.
Dec 09, 2008 | Nikon D70s Digital Camera
Over-exposure with AF Nikkor 70-300 telephoto
Friends have you tried not using the A-Aperture mode?? Set in on P-for Program or M-for Manual, this should produce the colors you are hoping for. If your photo is still "hot" use the + or - button called the Exposure compensation button on the top of the camera, push that little button and turn the outside main control dial where your right thumb sits 1 third stop at a time, (you have 4 to 5) The + adds light to your photo and the - will make your photos darker play with that and let me know. Barry Brown www.coralreefphotos.com
Jun 26, 2008 | Nikon D70s Digital Camera
Nikon d70 photo results
You might want to change the white balance or bracket your exposures
Here is a link to the photonet site that may give you some things to try: Photonet
Feb 23, 2008 | Nikon D70s Digital Camera
NIKON D70
The higher the ISO setting the more grain in the photo. Have you somehow set the ISO to say, 1600? http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b11&num=12 Select ISO setting this way: http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b05&num=10 Are you shooting in low-light situations (typically indoor)? Try shooting bright scenes and Auto mode, or manually set ISO to 100 or 200 and see if noise persists.
Apr 02, 2007 | Nikon D70s Digital Camera
Nikon D70s Digital Camera Logo
67 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
