Question about Car Audio & Video
Kec lsm104 wiring needed
I have just ontained a kec lsm104 overhead unit for a car and i need a wiring diagram for it. I need the diagram because i plan on using it as a computer monitor. I have a power supply for it but i need to know the rest of the wiring.
SOURCE: Need wiring diagram for 1997 Jimmy overhead console.
found one
Posted on Nov 23, 2008
  • 45 Answers
SOURCE: need to know wirring diagrams
the red is your memory alwayse is a live wire. Yellow tells cd player to turn on and off, Black is your ground. the other ones are your speaker wires go to your doors. Also if you have a power antenna it is the blue wire with the white stripe. Hope this helps
Posted on Jan 13, 2009
  • 10 Answers
SOURCE: I have a ASE380-UD440A PC. I need Pwr Supply wiring diagram.
It should follow the standard AT or ATX convention try this site
http://pinouts.ru/Power/
click on power supply connectors
Posted on Mar 14, 2009
  • 150 Answers
SOURCE: Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
Posted on May 21, 2009
My sunroof won't work in my 2003 Kia Sorento
It depends on the problem, in the diagram check the two fuses on the right, hot all the time. Not only check the fuses, check the fuses for voltage, use a testlite or something.
In the diagram on the right, is overhead console. If console problem, you may be able to use jumper wire on proper two terminals to close the roof?
In the picture on the left should unit/motor, if something wrong there, I don't know how to help you? If you need to dig in to the overhead lining? I can't help you.
Oct 19, 2016 | Kia Cars & Trucks
Cant pick up any channels on the kec tv in my chevy suburban
Please elaborate on the age of the tv. If it is an older tv it is analog, and wont pick up stations that are all digital.
Mar 19, 2014 | KEC Mobile Applications KEC Mobile Vision...
ADVENT ADV-35 wiring diagram
I need a wiring schematic for advent adv35 overhead 10' dvd player
Sep 19, 2013 | Pioneer Car Audio & Video
I have replaced....several times.... the 15amp fuse for my turn signal and overhead console read out and they continue to blow. All other lights continue to work, even the flashers, head lamps, and break...
When a fuse blows you have 2 choices
Replace it once or just go to the wiring
diagrams & start diagnosing & testing,
until you find the cause of the electrical
system problem causing the high current
You need to know what is on that fused circuit
Unplug the overhead console. If the problem
goes away, you know the console needs to
be checked out. Or you work on the signal
problem WITH WIRING DIAGRAMS
You wouldn't go on a road trip without
a map,if you never been there before !!
May 22, 2011 | 1998 Jeep Cherokee
How do I fix this unit? HAVE HAD this unit since
ei, configuring router settings is kinda diffcult for new users, in order to use your router,, you need to configure your tcp/ip setting of your network connections, and you must know the statis ip addresss of your router and manually used it in tcp\ip.. and you need t ontain the subnet mas and dns server setttings as well,,
Dec 28, 2009 | Linksys WRT160N Wireless Router
Overhead console wiring diagram
Compass/Temp w/o Trip function
Yellow - Key on 12v
Black - Ground
Light Green/ Black tracer Ambient air temp sensor At about 70 deg I have almost 10K ohms resistance. Just for a point of reference.
Dark Green VSS
Brown Goes to the dimmer switch that adjusts the brightness.
Gray Goes to headlight switch so the display will dim when the lights are on
Mar 10, 2009 | 1998 GMC Blazer
Sony mv-900sds overhead dvd
probably you will need to disamble it and remove check button. But the way I need instructions to connect it, I dont have wiring harness to connect it , can you help me with this?
regards
carlos.
May 01, 2007 | Sony MV-900SDS Overhead DVD/ 9" LCD Car...
Car Audio & Video Logo
449 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
