Question about Brother SE-270D Computerized Sewing Machine
Bobbin How did you fix your machine for $14.99???
    Problem Solver:
  • 3 Answers
Turn Tension know to zero before inserting cassette each time hen insert cassette and turn knob to 5-6-
. worked like a charm
Posted on Sep 30, 2008
're-please I just want to know how to fix bobbin
they have to be put in the machine in the proper direction .
Feb 17, 2016 | Sewing Machines
Just received a singer futura II model 920 which seems to sew just right. When I tried to wind a bobbin, I just can't get it done.
If it is a new machine, take it for warranty service. Sounds like perhaps something is misaligned with the release lever. In the meantime, a standalone bobbin winder can be purchased at JoAnn's, Hancocks, or Amazon.com for about $35 (helps reduce wear & tear on your machine).
It's very difficult to say whether it is worth the price of repair. On the other hand, what would you do with a machine that doesn't work? It could be something very simple that can be repaired for a small price, or it could be something expensive. (However, since you indicate it is only the bobbin winder that is faulty, otherwise the machine works with that one exception, you can save up to get the bobbin winder fixed.) FWIW, a standard check, clean & oil could cost around $100 (based on what I currently pay for my machines). However, you could ask what it would cost to fix the bobbin winder only.
From a search on eBay:
http://www.ebay.com/sch/i.html?_nkw=singer+futura+920
You can track similar machines and their sales prices to determine if it would be worth fixing your machine. Even if you don't, you can still purchase the standalone bobbin winder and continue to use the machine anyway. A working machine is better than none at all.
Feb 02, 2016 | Singer Sewing Machines
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
How do I fix error E4 whe no thread is tangled?
try changing the needle
rethread the machine top and bobbin
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
also possible that something has gone wrong with the computer
part of the sewing machine.
Nov 30, 2012 | Sewing Machines
Sewing Machine
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full & that it is inserted
correctly into the bobbin case
if none of these suggestions help,, it's also possible that the
machine could be out of time & would have to be checked at a
repair shop
Sep 07, 2012 | Sewing Machines
Sewing computer bobbin problems
you may need to take it to a sewing machine shop to see about getting it fixed
Apr 25, 2012 | Sewing Machines
I have rewound a bobbin on my sewpro sewing machine. When I loaded the bobbin back in the machine I can't get the machine to pick up the thread to sew again.
Welcome to FixYa. I always try the easiest fixes first - make sure your bobbin is inserted correctly, and that the bobbin thread is securely threaded in the bobbin case (sometimes the bobbin thread doesn't "catch" when you place it in the bobbin case). If all is well in the bobbin area, rethread your machine. Make sure that the presser foot is in the raised position when you thread. If it still isn't sewing correctly, change your needle. These last three steps fix most problems. But, if you are still having problems, look at the thread in the problem bobbin. It should be straight and tight. If it is kind of wobbly and a little loose, you'll need to wind the thread onto a new bobbin.
If are new to sewing, keep your manual close by and refer to it often. Simple mistakes can make a new sewer loose confidence, but it is all part of the process of learning your machine.
Good luck and happy sewing. If you have a sec, please rate my response so I know when I need to work on my responses.
Thanks for stopping in. Ginny
Jan 28, 2009 | Sew Pro QuickStitch SP-402 Mechanical...
Brother SE-270D Computerized Sewing Machine Logo
69 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
