Question about Nokia N95 Cellular Phone
N95 will not pair with Philips shb7100
Hi
Just got a philips shb7100, the nokia can pick up the shb7100 on the blue tooth, however they will not pair, have tried codes 0000 and 1234.
Jeff
  • benholm Oct 10, 2008
    I have this same problem and just contacted Philips about it. They promised to get back to to I will report what they had to say.
  • jeff2471 Oct 14, 2008
    hi it worked, thaks for the help.
    Jeff
The Philips tech-support asked if I pressed the connecting button on the blu-tooth dongle long enough or until it blinks back and forth from red to blue. This takes 5 s of pressing. After this the connection worked just fine. You can actually read this in the user manual too...
So don`t just start the SHB7100 when you pair it with 95, keep the button pressed down until the light shifts from blue to red and back after which you can enter the code 0000 and Voilà!
Posted on Oct 14, 2008
  • loiscycat
    loiscycat Feb 26, 2012
    Thanks "benholm"!! i can connect with my iPod Touch! --> "keep the button pressed down until the light shifts from blue to red " ... press pin code 0000 on iPod~~
  • loiscycat
    Thanks benholm. I can connect with my iPod Touch. --> "keep the button pressed down until the light shifts from blue to red " and press pin code "0000" on iPod Touch
My nokia 3230 was unable to perform bluetooth operation
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Nov 25, 2010 | Nokia 3230
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ┬▒ 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Hi, my problem is with my nokia bh-214 headset.. when i try to connect it asks for a passcode.. i didnt get on with the unit and have tried the recomended codes like 0000, 1111, 9999, 1234, none of...
when you are pairing the head set and phone make sure the blue light is flashing on the head set witch the blue tooth put the blue tooth on the phone when asked put 0000 they should pair
the head set has to be charged to us it
Sep 07, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My bluetooth dosent work in my nokia 6600
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back.
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Take care.
Jun 30, 2010 | Nokia 6600
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Cellnet Pico Bluetooth Headset wont connect to nokia 5800
Take care.
Jun 10, 2010 | Cell Phones
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Nokia N95 Cellular Phone Logo
461 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
